C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Fixed the starter now she stumbles
Old 10-20-2018, 05:25 PM
oldpro
oldpro's Avatar
Default Fixed the starter now she stumbles
hi first off car not throwing codes . Now that she is back together if snap the throttle with the car sitting at idle she stumbles then goes . If I am driving and floor her feels like she is just bearly missing . If I am cruising with the cruize control on going 70 and hit the accel button she stumbles a lot . Any ideas . I have pulled the plenum many times before . This is the first time I have had a problem . Any ideas ?????
Old 10-20-2018, 11:13 PM
ghlkal
ghlkal's Avatar
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
So, you obviously know about the different vacuum lines under the plenum ... that was going to be my suggestion
Old 10-20-2018, 11:31 PM
oldpro
oldpro's Avatar
The secondaries are removed on my car . I don't have a scan tool mine died
Old 10-21-2018, 05:31 AM
mhobtr
Support Corvetteforum!
mhobtr's Avatar
`Even with the secondaries removed there are vacuum connections. On my 91 the gas tank vent solenoid hose is easily knocked loose when reinstalling the plenum.
Any chance you altered the TPS calibration?
Old 10-21-2018, 06:58 AM
Dredgeguy
Dredgeguy's Avatar
Sounds like what happened to me. Check the fuel pump hose connections. One of the hose clamp had come loose and the hose was not connected tight to the fuel pump. Keep us advised and good luck.
Old 10-21-2018, 09:58 AM
oldpro
oldpro's Avatar
I was wondering if the tps was off but I have no scan tool to reset . Anyone know how to set this without a scan tool
Old 10-21-2018, 11:52 AM
mhobtr
mhobtr's Avatar
You can set the TPS with a volt meter. There are some threads which show which wire you need to connect.
What year is your ZR1? The early years use a physically adjustable TPS. The later years use a fixed TPS and computer calibration.
Old 10-21-2018, 02:27 PM
A26B
A26B's Avatar
An operable TPS position is horizontal, not angle up or down on the connector end.
Old 10-22-2018, 12:28 AM
oldpro
oldpro's Avatar
Thanx a bunch for that info on the operable range . My car is a 90 so it is the adjustable one . Going to
pick one up tomorrow and try will also see if I can find the thread on which wire to use .
Old 10-22-2018, 07:31 AM
mhobtr
mhobtr's Avatar
You may not need to buy a new TPS if your problem is the calibration.
Run the voltmeter test as outlined below. If the closed throttle position is set for 0.54V and if the voltage outputs are within spec when the throttle is opened, you don't need a new TPS,
BTW, if you do have to buy a new TPS, a local parts store will sell you a non-adjustable unit and try to tell you that it is the correct replacement. Look for the slots that allow the unit to rotate for adjustment.
https://www.corvetteforum.com/forums...on-sensor.html
Old 10-22-2018, 10:38 AM
ccmano
ccmano's Avatar
I agree, TPS voltage is critical. I’m running without secondaries as well and have found that correct TPS voltage seems even more sensitive. I found that even a small deviation causes a tip in throttle hesitation.
H
To Fixed the starter now she stumbles
Quick Reply: Fixed the starter now she stumbles
