Oil residue in supercharger snout
I was changing out my stock throttle body with a Ported one and once the TB was removed I noticed a brown color stain right by the snout which I can only assume is oil, it was just some residue. Is it something to be concerned about?
Received 8,928 Likes
There are some forum members who would have heart palpitations over finding oil residue there. Me, I don't think it means anything.
Bill
Bill
Received 1,817 Likes
Are you using an oiled air filter?
Just be happy you have warranty.
To me, when i changed my TB i didn't see an oil. But that was 5-6k miles ago.
I think as the mileage goes up, so will the oil residue take place? I think it's because we don't have catch cans on our cars.
I pull my supercharger cover every 2500 miles and wipe out the oil.the reason I do not install a catch can is it voids warranty.see my pulled the supercharger cover redux pics I just posted.
I just added a catch can for this issue. My car has a pretty big cam in it and it pulls oil past the pcv valve easier due to the lower vac from the cam.
Amirns (10-23-2018)
Supporting Vendor
removing the lid to sop up oil that did collect, is not doing anything for the rest that went on in.
also, car manufacturers can void a warranty for any reason they want, they have no particular beef with catch cans or headers, but if they can blame a problem on something or someone else you can bet they will try. for example like the customer partially disassembling their engine prior to the claim... just sayin.
Supporting Vendor
the pcv valve is an air flow regulator, not an on off switch. piston type units like the one in these cars have a curve that goes up and down, not just up.
any other catch can companies flow the stock pcv system? just kidding i know you haven't.
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
#mmsolutions
i can help with that one
Are these numbers vacuum, boost, fuel compensation trim numbers, or what?
Supporting Vendor
https://www.corvetteforum.com/forums...catch-can.html
according to GM,thats normal.it sucks,but a catch can will void your warranty.catch can manufacturers wont tell you this.would you if you made them?here is the proof.pull the cover and keep it clean every 2500 miles,not perfect,but cant hurt.READ HERE
Z0HS1CK (10-23-2018)
Supporting Vendor
