[C1] Fan shroud
Fan shroud
I have an electric fan with no shroud. I am considering putting the shroud back on at least the top and sides. Other than I think it looks better will it help cooling or hurt it?
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
I run both the factory engine driven fan AND an electric puller fan behind my rad. in my 1957 with 383 stroker engine. The electric fan aids in cooling when stopped or low speed driving. If you run an engine driven fan with shroud the correct placement is with the fan blades 1/2 in and 1/2 out of the rear edge of the shroud when view from the side of the car.
St. Jude Donor '07
my .02... the shroud will not help with only an electric fan as the only air that the fan will pull through the radiator will be that section directly in front of the fan. if you have an electric fan with a shroud made specifically for that fan, then a specific shroud will help, not a factory shroud; look at the fan that Dewitt sells and you will see what I mean.
check this link for an example of how to install an electric fan only: https://www.corvetteforum.com/forums...ud-set-up.html
Bill
Bill
Bill
Bill
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
When you are not moving, the fan has to "suck" air through the radiator in order to help.
Air takes the path of least resistance.
So if the fan can't create a low pressure area (slight vacuum), it's not going to help much.
St. Jude Donor '07
if you have the factory engine driven fan and the factory shroud, then the addition of an electric fan will help suck additional air at low speeds but will be of little to no use on the highway
I use a pusher fan in front of my a/c condenser to provide additional airflow at low speeds and to help overcome the air flow blockage from being in front of the radiator; again, at highway speed, fans are of little use.
Bill
A lot to consider
Well you have all given me much to think about . I'll add a few things. Engine is a zz4 350 the current 16" fan seems to work well even with the stk generator and radiator. Runs at or near 180 even on 90 deg days usually but I have seen it up to 210 which is one reason why I wanted to install the shroud. I have the fan on a thermo switch and it has not yet blown a fuse. I think I will go ahead and get the missing parts for the shroud rubber seal it for a tighter fit and see what happens next summer. Thanks for all your help.
you don't need 2 fans, just the proper shroud as in the link I posted above.
Bill
Bill
My 57 ran perfectly cool with the original rad. engine driven fan and shroud until I upgrades the engine to a 383 with 11 to 1 aluminum heads. Then I added the electric fan and still had cooling problems. I upgraded to a Dewitt rad. and since I already had the electric puller fan I used it but don't really know if it was necessary. I am not a "fan" (no pun intended) of pusher fans as by their nature block air flow over the surface of the area they are mounted to. A puller fan would suck air through the A/C condenser as well. The problem with A/C cars is that the hot air from the condenser is being sucked directly on to the rad that is trying to get rid of it's own heat.
St. Jude Donor '07
Bill
