Npp/dual exhaust
Hi - I'm looking to do the same! I have a base C6...they should fit, correct? BTW, if you don't mind disclosing, what did the mufflers run you? You can PM. Also, are they an easy swap?
Thanks,
Jon
Thanks,
Jon
I don't believe GM sells them...it was an option price he quoted. NPP is a system, not just the mufflers. If you install just the mufflers, which is fine, you will always have the baffles open.
A used set will usually run from $200 to $500, depending on how bad the seller wants to get rid of them. They are very stout, and there is little actual "wear" to worry about.
Great, that is what I was looking for, I know GM does not sell them off the shelf. I know the NPP for Z06 has a 3" as opposed to the base 2.5" (I think?). Tough to locate a set. I was under the impression that the baffle valve was in b/w the muffler and tail pipe? If not, I guess mild or wild won't work?
Jon
Jon
Jon
Jon
https://www.nakidparts.com/c6-corvet...etrofit-system
Depends on what year your installing them on,make sure you purchase the right set,2009 and up are all the same but 2008 the bend on the right muffler is different.If your trying to put a 2009 and up set on a 2008 you will need the H pipe also
Your car should be 2.5". I'm sure you can buy the muffles from GM if you want new ones. I did for my 07 but it was a long time ago and I forget the price. The valve is part of the muffler, but you need the NPP in a box to control the valves. The M2W is just a switch for a car that has the factory vacuum system.
jbripps (10-22-2018)
I found the NPP system for a 2008 base on eBay for my 2007 base. Very easy to hook up. I think I paid 4 or 5 hundred dollars.
Wow - this is more complicated than I thought. I have a base 06A....so I would need the non Z06, and base NPP mufflers, but not from an 08....sound right? Really appreciate the education, I did not see any prior threads with this much depth.
Jon
Jon
Received 1,636 Likes
I have the NPP dual exhaust, but it's more like a single exhaust mode since I keep them open 99% of the time. And the sound of the open NPP exhaust is OK but still not great. If I had a car with the standard exhaust, I would probably look at going with an aftermarket exhaust instead. Even with my NPP exhaust, I am sometimes tempted to go with a Corsa or some other aftermarket exhaust.
Pretty sure you'd be ok with base 08 setup. It won't work with 09 and newer on your 06.
Yes you need a set for 2008 only,if you want to use a mild to wild switch you will need to purchase NPP in a box from a vendor on here and install. If you find a set with H pipe cheap (2009-2013) it’s an easy install
Jon
Received 2,060 Likes
C6 of Year Finalist (performance mods) 2019
BTW, fill out more than just "male" on your profile, so people know what you're driving and where you are from. It avoids the 20 questions game.
jbripps (10-24-2018)
