Blown engine
Blown engine
Is it possible to blow the engine on a 2019 Grand Sport when you hit redline or is there a limiter to prevent that from happening?
Runflatred (10-22-2018)
It’s a fuel cutoff. More than one person has missed a shift, gone into the wrong (lower) gear, and grenaded the engine. Not a limiter in the world that can beat physics.
Received 2,225 Likes
You can't over rev the engine unless you have a manual trans and drop it into a low gear at high speed. The automatic will not allow you to do that. Under normal acceleration the rev limiter will prevent over reving the engine
E-Ray, 3LZ, ZER, LIFT
Received 9,622 Likes
Now if you have an M7 and were shifting 3rd to 4th at 6500 rpm but by mistaken instead of pulling straight back pulled the shift lever toward yourself you would be in 2nd gear. The instant the clutch was engaged you would be set to have the engine turn 9400 rpm. The tires would loose traction and you would not reach that but be well over 6600 rpm and bend some push rods as a minimum if not worse! Not covered under warranty as the rpm excess would be recorded!
If speed shifting that is only 103 mph so at a drag strip easier to do that one would think! The good news is you'll only do that once!
I have a manual and in fourth gear I hit 152 at redline. Car was still accelerating but I backed off because I didn’t want to blow the engine. I still had about 1500 of straight before turn one. I was on a track. So basically what I was asking is that if I kept my foot on the gas a few more seconds to get it up to 155 or 160 is there anything on the car to prevent the engine from blowing up? I heard there was a rev limiter but don’t know if it would help in this situation. Thanks again.
Regardless of gear when it hits 6600 rpm the fuel shuts off, you'll feel it Comes back on quickly when you get below. My math says you were at all you'll get. May feel like it was pulling but you'd never get to 155 without shifting.
Heck I don't track but live in a rural area with no traffic or homes between long straight roads with cotton fields on both sides. I've hit redline a few times in 1st and 2nd and occasionally 3rd! That is a fast as I'll go! You should try in a lower gear so you know what it feels like. Could try to shift to 5th at 152 mph but with the excitement of a turn coming just be sure you're going into 5th NOT 3rd!
Yea thanks for the reply. I tried shifting into fifth a few times but as soon as I step on the clutch I loose 10 MPH. Shifting at redline without taking my foot off the gas wasn’t an option I wanted to try either. Not enough time or straight track to get back up to speed before the turn. I should have gotten automatic. I was able to hit 160 on the same track (Pocono Raceway) many times with my 2013 Grand Sport even though that car had 30 less horsepower. The difference was that car was automatic and my 19 is manual. Oh well, I still love driving my new car.
I know the C5 has a computer controlled limit, but I also know it does not always work. (Its a long story - suffice to say GM bought a new motor for my C5 when the limiter failed to do what it was supposed to do when it was supposed to do it.)
Given there is a limiter on the C5, I would venture there is also one on the 7.
Runflatred (10-23-2018)
Miller Time Wisconsin 🍺
Location: The only thing we have to beer is beer itself 🍺
Received 1,440 Likes
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
My GS will hit the rev limiter at 151 mph in 4th gear
Suggest all who drive aggressively try it in 1st or 2nd to feel what it does. No harm as the engine won't explode at 6800 rpm, which you'll never reach! Easy to do with an M7 but not sure if with an automatic in manual mode the trans won't shift.
I am not sure how the transmission will respond in manual mode if you are heading down a sufficiently steep slope which will force the engine above redline if brakes aren't applied and I am definitely not going to experiment with this scenario.
I've hit the rev limiter twice now in my A8 GS, first time I was in Drive and downshifted using the paddle to do a 50 mph roll-on and it didn't up shift automatically. Lesson learned when in Drive and you start using paddles it switches to M mode. Second time I just didn't shift fast enough from 2nd to 3rd in M mode. So the rev limiter did what it was designed to do.
The automatic in manual mode won't automatically upshift either and will just run at the limiter like the M7. The only time the auto will shift automatically in manual mode is when slowing down it will downshift in manual mode. But it won't upshift automatically at redline in manual nor will it force a downshift if you go to full throttle while the engine is running at 1,500 RPM on the interstate.
Would have to be a very steep hill! In the lower gears it is accelerating rapidly pushing you back in the seat and then suddenly zero acceleration!
