Take A Guess On Horsepower!!!
I'm taking bets!! Just kidding
My buddy and I are just making a friendly $10 bet on what hp I'll make with my mods. Hopefully having it tuned this Friday, just finished up the cam install. Here is my mod list for my 2000 C5 FRC:
Ziptie mod with k&n filter
LS6 intake manifold
LT headers
Deleted pup cats(still running main cats)
Magnaflow XL system cat-back exhaust
Jegs cam 228/230 .585/.585 112lsa
Scoggin Dickey Dual valve springs/titanium retainers
Car has 28k miles on it. He says I'll touch 400whp, I think I'll be at 389whp. The car will be dyno tuned on a dyno where the axles bolt to the dyno machine, no rollers. Take your guess everyone!!
LS6 intake manifold
LT headers
blacktapeandnails (12-14-2018)
Dang, I wanted 370... I'll pick 364
NCM Lifetime Member
Received 3,930 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
390 rwhp
Received 3,812 Likes
St. Jude Donor '03-'04
Since all dynamometers are based on the software used and the actual mechanical integrity of the dyno. Of the three, Dyno Jet, Mustang, and the third and least accurate Portable Dyno-mite ( portable axle mounted dyno ) The DynoJet is the most favorable for printing out higher HP and torque numbers, and the most accurate of the three; Mustang dyno. None of these are capable a showing true HP at the crank, without a variable drive line calculation, which would have to be changed for each car since all cars have different drive line drag. GM uses a true dyno to measure HP and torque at the crank. Keep in mind that dynos are all accurate in delivering relative numbers. meaning, if you use the same dyno, and add a modification, it can measure the difference between the before and after. The difference in these three dynos could be as much as 50 HP and torque at the wheels when measuring the same car. So with all that in mind, the topic line says it all.. " Its a Guess ", even when the dyno prints it out. Understanding what a local shop, or a portable dyno delivers will help understand that none of these are actual true HP or torque numbers.. just a relative base line to use the measure changes. OH and BTW, the more sophisticated todays cars become to overcome driving conditions, the less accurate these shop dynos become. If you want some sort of bragging rights, use a DynoJet. If you want closer to actual numbers, use a Mustang dyno. They can all measure changes in engine modifications.
Bill
Bill
The following 3 users liked this post by Evil-Twin:
Received 19,302 Likes
'20-'21-'22-'23-'24
Good info by E-T. I'll take a guess and say 375 rwhp.
Bill
Bill
Great information and thank you. The dyno that I use to have my cars tuned on was a Mustang dyno. But unfortunately my friend is just too busy to tune my car. So this will be the first time I've ever seen one of these types of dynos used. Didn't know they show lower numbers. Either way, numbers are numbers. ET and seat of the pants will say it all. But like you said before, as far as measuring when I do more mods, it will be my new dyno/tuner I will he going to.
I hope this help people to understand true HP and relative HP.
Bill
Yello95 (12-17-2018)
What cylinder heads are on the engine? I have similar mods (cam, LS6 heads, LS6 intake, LT headers, x-pipe, exhaust, Varraram ram air intake & air bridge) and I just tuned at 422rwhp on a Mustang dyno.
The cam is the biggest variable. I have a 224/224 563/563 114LSA.. You should see around 390-400.
As far as heads, I have the stock 853 heads on my car. But I did pick up some 243 heads with only 20k miles on them from an 04 Z06. I'm porting them and then going to have a valve job done in the winter.
With the 243 heads and a tune you basically would have a LS6 engine with CIA and a hotter cam. I would expect similar results as others with similar mods.
You might see a 50hp gain over the LS6. The heads may account for about 15-20hp. You could gain 10-15hp by raising the compression ratio a little. If you do I would lower the temps to keep the heads cooler.
Without a tune you may not see much of a gain.
As far as heads, I have the stock 853 heads on my car. But I did pick up some 243 heads with only 20k miles on them from an 04 Z06. I'm porting them and then going to have a valve job done in the winter.[/QUOTE]
Are we guessing on the 853s or 243s?
My 375 hp guess was stock heads
I have a similar mildish cam (222/226 .600) with ported 243s and it hit 402hp on a dynojet.
I'll guess 400 with the heads.
