Lug nut problem
Old 10-22-2018, 02:40 PM
I Fly Low
Support Corvetteforum!
I Fly Low's Avatar
Default Lug nut problem
While changing brakes this weekend,torquing my lug nuts, about half of them had the same issue: at about 90 ftlb, there was significantly less torque, for about 1/6 of a turn. after that, they would tighten up again and I was able to torque them to 100. Checked them all after a short drive, and they all held torque.
Could this possibly be worn lug nuts, or indication of a future problem? Since I have owned the car, I have used an air wrench to remove and torque wrench to reinstall.
Old 10-22-2018, 04:28 PM
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
C6 of Year Finalist (performance mods) 2019
How many miles and more importantly, how many wheel changes, as in off and on?
Old 10-22-2018, 05:02 PM
I Fly Low
I Fly Low's Avatar
102K, wheels off and on 10-15 times
Old 10-22-2018, 06:56 PM
GMJim
GMJim's Avatar
Are you using any lubricant? Never lubricate lugs or lug nuts.
Old 10-22-2018, 07:34 PM
919cw313
919cw313's Avatar
Received 2,683 Likes on 1,408 Posts
2018 C6 of Year Finalist
Is there a chance your wrench is messed up instead of the nuts or studs?
Old 10-22-2018, 08:23 PM
Allset
Allset's Avatar
Check on your wrench properly ..
Old 10-22-2018, 08:27 PM
CorvetteSparky
CorvetteSparky's Avatar
Is it possible the wheel was just snugging up tight to the hub? What method were you using to keep the wheels from turning?
I Fly Low (10-30-2018)
Old 10-22-2018, 08:35 PM
NY09C6
NY09C6's Avatar
This would be my guess.
Pull only one lug, look for metal shavings on the stud and inside the lug, then put it back on and torque it. If it does not 'lose torque' again, it was likely the wheel pulling onto the hub. You can repeat for all 5 to be sure.
To Lug nut problem
Quick Reply: Lug nut problem
