2005 M6 1st and 2nd gear hard to input
Hi, I have an 05 M6 with 66K. I have the skip shift eliminator which is great! However, I find that 1st and 2nd gear can be challenging to downshift into. Has anyone else had this issue?
Received 3,624 Likes
2016 C6 of Year Finalist
No rev matching. Even 1st gear doesn't always want to go in at standstill. So I start to roll in 2nd and then put into 1st. This does not happen all the time. Clutch feels fine, have done the ranger method on the fluid.
I'd check the shifter rail alignment. This usually is the cause of a lot of problems getting into gear. While in there you can also inspect the slop of the shifter and the shifter ball/cap piece to see if its worn down too much.
I think the alignment mention is more accurate. Anyone have the MGW shifter or other replacement brands? Is it worth it?
If I remember for the manual the ATF has to meet Dexron III standards, so check the RedLine type the transmission shop used.
