FS: Build parts
LS6 top end parts
I have some stock and aftermarket parts left over form a top end build. All parts were off or for a LS6 Z06.
GM LS aluminum rocker arm pedestals $30 for the pair shipped.
GM LS6 78mm DBW throttle body $100 shipped.
GM valve spring reatainers with locks $30 shipped.
Cam Motion steel valve spring retainers, no locks $25 shipped.
Tick Performance chromolly pushrods NEW 7.425" $60 shipped.
GM LS steel rocker arms 1.7 ratio, kept in oil to prevent rust. $80 shipped.
SOLD Lingenfelter 160 degree thermostat NEW $30 shipped.
Stock LS6 cam (2003 specs) $200 shipped.
Received 3,043 Likes
St. Jude Donor '05
Loking to do a bare bones 5.3 build what do you have that I can use? Small cam/ported heads type thing.
I have the stock ls6 cam out of 03 z06, GM stock 1.7 rocker arms, the rocker arm pedestals, GM valve spring retainers with locks, commotion valve spring retainers no locks, tick performance 7.425 hardened pushrods, and ls6 78mm drive by wire throttle body
