C7 Parts for Sale/Wanted C7 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
FS: Vengeance Racing Used and New Parts via EBAY
Old 10-29-2018, 09:05 AM
0Vengeance Racing
Former Vendor
Vengeance Racing's Avatar
Default Vengeance Racing Used and New Parts via EBAY
Please click the links below for more information... You can make offers through the EBay listings
C7 Specific Items
C7 Corvette Clear (tinted) Removable Roof
LT1-LT4 Throttle Body (Gen 5) 12678223
Procharger GM Gen5 Intake Manifold for LT1 or LT4
GM Factory LT1 Pistons & Wrist Pins (Gen 5)
C7 Corvette Stingray Alternator - 22868687
LT1 (Gen 5) Oil Pump - 12686436
LT1 (Gen 5) Rear Engine Cover - 12623310
C7 Corvette LT1 Oil Cooler - 12658068
C7 Z06 18% Overdrive Pulley
C6 Specific Items
C6 Corvette Headlights - White (2005 - 2013)
Vengeance Racing Tall Valve Covers - LSx Gen 3 or Gen 4
McLeod Mag Force Clutch For LS Applications - Twin Disc
FTI Torque Converter for C6 Corvettes - 6L80 Trans
Wiseco Forged Pistons for LS Engines -27cc 4.135" Bore
GM LS Rear Engine Cover - 12572014 (Gen 4 Engines)
C6 Z06 Complete Torque Tube - 19132932
Vengeance Racing Camshaft for Supercharged LS7 Engines 239/254 .662/.651 115+4
C6 Hood - Black
Hydratech Brake Boost System For C5 Or C6 Corvettes (#3009-BASE)
C6 Custom Air-to-Air Intercooler (1000HP+)- For Twins
C6 Z06 Door Panels - 2007 - Ebony (with Bose)
C6 Z06 Rear Splitter - Carbon - Gloss Black (2007)
C6 Z06 Non-Removable Roof Panel (Hard Top)
ARE LS7 Style Dry Sump Pan With 2-Stage Scavenge Pump
C6 Passenger Side Air Bag
C6 XM Radio Antenna
Rear Cover for GM LS Engines - 12598301
C5 Specific Items
C5 Z06 Front Sway Bar FE4 / Z06 10419094
C5 Z06 Rear Sway Bar FE4 10424743
Mechman C5 Corvette, 170 Amp Alternator
C5 or C4 Corvette Headlight Module - 16523917
C5 Wiper Control Stalk Switch - 260047377
C5 A&A Corvette Secondary Belt Drive (single Bracket And Belt Only)
General Purpose Items
Turbo Guard SF, 5-Inch
FTI Triple Disc Torque Converter for 4L80E and LS
Toyo Proxes A40 Tires 215/45R18
Gates 10-rib Green Belt - K100658HD
Gates 10-Rib Green Belt - K100655HD
Manley Chrome Moly Pushrods 7.750" .080 Wall 3/8 Dia
Carillo Connecting Rods - Custom 6.460-Inch
Gates K080842 8-rib Belt
Gen 3 LS Valve Covers
MAST Motorsports Rocker Stands LS7 Big Bore Heads
Casper's Electronics LS Coil Pack Extensions (Pair) - 109082
Fabricated Fuel Cell / Ice Tank / Trans Cooler Box - NCC (No Corners Cut)
Morel LS Tie Bar Lifters - 5850 - Short Travel
Pro Torque Converter TH400
DCM Axial Electric Puller Fan - 860026
Holley 860015 102mm Sniper Throttle Body Spacer
Mass Airflow Sensor For LS Engines - 5-Wire
Cometic LS7 Head Gasket - C5889-070
Wiseco Wrist Pins For LS Engines
Mantic 9000 Series Flywheel - F9001H
Gates K080855 Belt - 8PK2173
CM Pushrods 7.225" 5/16" .080
CM Pushrods 8.050" 3/8" .080
Cometic MLS Head Gasket (Left Side)
Durabond CH-23 Cam Bearings
Old 03-01-2019, 11:57 AM
Bruce_K
Bruce_K's Avatar
any pics of that cargo matt?
Old 03-01-2019, 12:04 PM
0Vengeance Racing
Former Vendor
Old 03-01-2019, 12:07 PM
Bruce_K
Bruce_K's Avatar
Thanks guys! I was looking for the one with the flag!
Old 06-26-2019, 11:24 PM
Nghia Vu
Nghia Vu's Avatar
would you do free shipping on that starter ?
Old 07-31-2019, 12:33 PM
Chazzmania
Chazzmania's Avatar
Originally Posted by Vengeance Racing
Mid week bump
In the regards to the cam I am looking for one that will work with my LT1. I know this one is labeled for LT4 and on the Vengeace Site you can pick LT1 OR LT4 just trying to see if there is a difference and if this cam would work with a centrifugal blower setup.
Old 07-31-2019, 12:41 PM
0Vengeance Racing
Former Vendor
There is no physical difference. The LT4 cams are designed for forced induction so the spec's are a little different in that respect.
Old 07-31-2019, 12:53 PM
Chazzmania
Chazzmania's Avatar
Ok so I could run this in my LT1 if I plan to supercharge the car?
Old 07-31-2019, 01:02 PM
0Vengeance Racing
Former Vendor
Yes!
Old 07-31-2019, 01:49 PM
Chazzmania
Chazzmania's Avatar
Yes!
Could you send me a price with shipping out to 96706?
Old 07-31-2019, 01:51 PM
0Vengeance Racing
Former Vendor
Please email me your full address to:
todd@vengeanceracing.net
Thanks
Old 08-11-2019, 06:08 AM
Pacembellum
Pacembellum's Avatar
Any c7 zr1 exhaust take offs?
Old 08-12-2019, 09:08 AM
0Vengeance Racing
Former Vendor
Not at this time....
Up for a new week
Old 08-28-2019, 12:04 AM
JT Corvette
JT Corvette's Avatar
if you guys ever remove a set of Z07 springs, please let me know!
Old 08-28-2019, 01:01 PM
JT Corvette
Valve springs? Leafs?
Bump
Leaf springs
Old 08-30-2019, 11:39 AM
0Vengeance Racing
Former Vendor
Originally Posted by JT Corvette
Leaf springs
Not common for us to remove those, but we will let you know if we do!
Old 09-13-2019, 12:04 PM
hamad_alz
Support Corvetteforum!
hamad_alz's Avatar
When is the new list coming?
To Vengeance Racing Used and New Parts via EBAY
Old 09-13-2019, 12:09 PM
0Vengeance Racing
Former Vendor
New list? We always use the same list and just update it when new items are added or items get sold.
You can save out store if you have eBay and check there for new items added.
Old 09-30-2019, 11:37 AM
KENS80V
KENS80V's Avatar
One of your EBay listings states LT1 or LT5 throttle body. I'm sure that was a typo as it should say LT1 or LT4 throttle body.
Vengeance Racing (09-30-2019)
Old 09-30-2019, 11:43 AM
0Vengeance Racing
Former Vendor
Got it fixed up. thanks!
Quick Reply: FS: Vengeance Racing Used and New Parts via EBAY
