1971 info
2021 C2 of the Year Finalist - Unmodified
2017 C3 of Year Finalist
St. Jude Donor '13
1971 info
Well I did post a 'help please with this car' and a description of what I new including the VIN then went to edit and add pics and lost the lot. I'll redo one post down
St. Jude Donor '13
So I'll try again.
Looking for info on 1971 coupe VIN: 194371S107270. I googled the vin & checked the C3 registry without success. No pics yet of the tach or console plate and have no idea of birdcage, mounts & frame condition. It's a lady looking for info on her recently deceased husbands car.
Any help in decoding what this was / is gratefully received.
Stuart
Stuart
St. Jude Donor '13
you need to provide the engine code, letters, found on the pad in front of the passenger side cylinder head. You can compare the last 6 digits of the VIN to what you find on that same pad to see if they match.
Received 1,469 Likes
Cruise-In II Veteran
Engine is dressed like an LT-1, but all of those were four speeds.
St. Jude Donor '13
The car is a ZQ3 base engine (350ci - 270hp) coupe with an automatic. The tach will have a 5300 rpm redline.
The car has been dressed up to look like an LT-1 with hood, valve covers, air cleaner sticker and I'll assume console plaque.
St. Jude Donor '13
St. Jude Donor '13
Thanks. I'm digging and being told that the pics may be up to 2 years old and it's sat outside and much worse condition now. Shame but for her, I'll go and see it anyway.
A pic of the trim tag inside the drivers side door frame will be a big help in noting if the car has had a color change.
I REALLY like this car, but I may be biased. Ours is also a base 270 horse, automatic, non AC.... and I changed the reverse lights out to have 4 stop / tail / turn signals. Ours is Steel Cities Gray (original color), but we would paint it yellow if we ever decided to change it! Good luck with your research. I LOVE those wheels & sidepipes too, by the way!
Check the tach as mentioned... also any 70-71 LT1 cars should have the inner fender holes for the TI box even if the system is missing.
probably a 270 HP 350. ONE thing to note, the push in oil cap, though the cap is later, if the valve cover is a real 71-72 cover with the smooth round opening for the push in oil cap, they are rare and have not been available for years... Perhaps the car was done with a donor car. I see what appears to be a plug for a smog hole in the manifold, only 71 SB with smog was the LT1.as well.
St. Jude Donor '13
St. Jude Donor '13
What on earth can be made of this ?
CE indicates an engine replaced under warranty. TXB is the ID code for a 75-77 truck block. The 70 appears to be hand stamped.
A replacement engine? Looks like a '75 Camaro or something, changed under warranty...?
Ooops! Mike beat me to it!
St. Jude Donor '13
Stuart
St. Jude Donor '13
