WTB: NOS GM Cam shaft Part # 3863143 69 427
Need a NOS GM Cam shaft Part # 3904362 for a solid lifter engine
for a 69 427
Took the engine out to rebuilder and he says I need a new cam
If you have an NOS one please email me your asking price
grantwong@telus.net
Thanks, Grant
The above title should be part number 3904362 not 3863143
for a 69 427
grantwong@telus.net
Thanks, Grant
ttt
Can someone tell me what is the factory duration and lift for a 69 427 435hp cam is
Thanks, grant
Found duration but the Correct cam I need is for a 69 which is part number 3904362
Thanks, grant
Grant,
In the Alan Colvin books - Chevrolet by the numbers (both 65-69 and 70-75 books) - he shows the 143 and 362 cams to have identical specs. Lift with 1.70 rocker ratio is .520 and .520; duration shows to be Intake - 316 degrees and Exhaust - 302 degrees. If there is a difference, I have not found it yet. Troy
