C5 modernization
C5 modernization
Hey guys,
This has probably been asked before, but I just bought my first C5, and I absolutely love it. I'm over my fear of driving when I'm behind the Wheel. However, I'm looking to personalize my baby, starting with some modernization..i.e: upgrading sound system, adding backup camera, ect.
I'm asking because I'm looking at parts and would like your guys input of your own projects and parts used. I'm a little nervous because if I go out and buy a part, it might be non compatible, hoping to hear from ya.
Cheers.
Cheers.
1/4 mile/AutoX
I already had a DD bezel, and I just added a Android Radio, it has everything !!!!!
Jimmy Batista (11-06-2018)
1/4 mile/AutoX
AC ***** are C 6 from E-bay, yes I kept the Bose ( a lot of people don't like them, but I do !!!) MGW Flat sick with lower box, complete interior is sound and heat proofed with Fat Mat from Amazon !!! have a ton of mods done to this car, balancer just went to crap so now it's time for cam and heads !!!!! (it NEVER ends) !!!!
C6 hvac *****, WTF. Just kidding. Looking good pounder.
1/4 mile/AutoX
Regarding the headunit, these are basically the main options available. If you want to keep the Bose infrastructure, Option 4 is the way to go.
- Replace just the headunit, leaving the rest of the system intact using
- (this one preserves the RAP feature)
- Keep the headunit, but replace everything else adding a multichannel external amp driving new speakers through new wires by using
- Replace just the 4 twiddlers with 2-way coaxial speakers leaving the rest of the system intact
- Combine 1 and 3
- Take everything out and replace all from scratch
That being said, without a doubt, the easiest and least expensive way to upgrade the system with the more bang for your buck is new speakers that can be bolted on in place of the factory ones, keeping the rest of the system intact.
The C5 OEM speakers do not include any real tweeter. Bose used 4 plain-cone (paper) speakers to handle high and mid frequencies and called them "twiddlers". That's why you can make a big improvement by replacing them with a 2-way coaxial design.
OEM C5 Speaker Sizes:
-Front
Twiddler: 3.5"
Subwoofer: 8"
-Rear Twiddler
Coupe: 6.5"
FRC/Z06/Convertible: 5.25"
For bolt-on speaker upgrades, get 3.5" 2-way coaxial speakers to replace the doors' twiddlers and 2-way coaxials of the right size for the rear. Don't touch the OEM subwoofers.
A quick search produced this:
JL Audio Evolution™ C2 Series 2-way car speakers:
- C2-350X (3-1/2")
- C2-525X (5-1/4")
- C2-650X (6-1/2")
Not only they are from the same manufacturer, but they all belong to the same line. This should reasonably assure you they have the same timbre.
You are going to need as well. One kit will do both rears.
Independent confirmation that upgrading the 4 twiddlers makes a noticeable and worthwhile upgrade.
Received 19,275 Likes
'20-'21-'22-'23-'24
You'll get plenty of opinions on which system is the best for your car. Just take your time, do your research and then decide. You may also want to get some input from the Audio/Electronics section of the forum.
The following 2 users liked this post by Ramets:
Pounder (11-07-2018),
SpeedRacerMach (11-13-2018)
Short list of best "modernization" mods:
MGW shifter w/ lower box + dynamat over tunnel
Radioflyer headlights
LED taillights
swap out speakers for higher end + dynamat/sound deadening in doors/behind seats
Swap out head unit for DD or new stereo w/ bluetooth mic
Leather replacements for shift boot/parking brake
Steering wheel swap
seat swap
wheel swap/upgrade to C6 style or 18"s front/19"s rear
lowered some on stock bolts
Rear tray/partition - particularly on FRC's or Z06 models
These are pretty much the most significant mods you can do to "modernize" a C5 IMO - and I've done some myself (headlights/shifter/dynamat/stereo)
Enjoy!
LED taillights
Steering wheel swap
seat swap
Enjoy!
I had a pretty good case of wanting to modernize myself. I did several of the things including stereo, seats, MGW shifter, etc. You can see a lot of it in this thread I did a while back - https://www.corvetteforum.com/forums...ld-thread.html
I kept the stock Bose amp and speakers. Used the PAC ROEM VET1 interface to an after market single din touch screen BT CD DVD and backup cam. It's easy install pretty much plug and play.I am pleased with the sound and all the functions. Setup on the head unit was a PITA. I'm guessing a 12 year old would have had no trouble with it. The touchscreen flips up in front of the A/C vents but that's ok because I only use the screen when backing up. Other times keep the screen folded in. I went with this head unit http://www.pyleaudio.com/sku/PLTS78D...io,-Single-DIN
PS. I did not pay anything close to the $419.99 in that ad.
1/4 mile/AutoX
when I first got my Vette I wanted to SC it, waaaay to much money !!!!!! have LS 6 intake and headers, now cam and 243 heads are in the works along with a M12 trans, should make it fun for maybe a year ?????
When I got my kit, I talked to Andy at A&A, and he built me a custom kit for under $5k. I get 8.5 lbs of boost with the stock pulley, and 634 RWHP.
Depends on your budget and what you mean by modernize.
Modernizing the look would be lighting, both interior and exterior, to HID and LED.
1. Radio Flyer BiXenon headlights
2. RF LED fogs
3. RF exterior/interior LED kit
(Yea, I like Georges products )
For drivability and performance
c6 shifter, swaybars, shocks, etc
I suppose you could call the audio system either a creature comfort or convenience if you get one that supports Nav, XM, and or phone inputs.
2. RF LED fogs
No doubt they're a great company & make a great product....but that price point is misleading, ya sure $5k for the SC kit.....what about clutch? Meth injection? Fuel system? Install/tune? To me in order to do it right looks more like a $7-10k job depending on what you already have done and/or need & whats addressed (doing torque tube bushings, rear main seal, etc. for example)
