C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Best Big TB?
Old 11-08-2018, 04:26 PM
Bruce_K
Bruce_K's Avatar
Default Best Big TB?
Hello all
Just need some help. im getting my blower ported soon. and wanted to upgrade the TB. is there a huge difference between the ZR1 95mm TB and the 102/103/106 TB'S? i know bigger is not always better and it is getting a tune but im worried about driveablitly as well.
Old 11-08-2018, 06:56 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Originally Posted by Bruce_K
Hello all
On the 102 & above you better have a EXCELLENT tuner on the hp tuners. If not you will be taking it off & selling it I know they give you the paper for the % on it to do this & do that. But still need a lot of help for the normal street part of that big T.B. The 95 will be all I am going with on my new forged build. Robert
Old 11-08-2018, 06:57 PM
jrwood
jrwood's Avatar
Hello all
I just had this conversation with MTI in Houston. They had a lot of good input on it. I’ll see if they can post up their findings.
Old 11-08-2018, 07:10 PM
robert miller
Default ttt
The 95 zr1 t,b, would be the one I would am going with on my new build. I have seen so much problem on the bigger one on the street tune in having problems.
Old 11-08-2018, 07:11 PM
douniasg
douniasg's Avatar
I went with the zr1 tb. I think it should be good enough for the z06 blower. Plus I got everything for around $250 and I opened the snout with drill and sandpaper roll. Just waiting on MTI's fuel system then a dyno tune.
Old 11-08-2018, 07:19 PM
Bruce_K
Bruce_K's Avatar
I'm getting it ported so it may be opened up to like 103 was why I'm.asking.
How much HP did you gain?
I'm doing the same thing.
And BILLLLYY chime in.
Old 11-08-2018, 07:40 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
The 103 is the best. A PD blower wants as much air as it can get.
Old 11-08-2018, 07:50 PM
Bruce_K
Bruce_K's Avatar
Thanks Billy, 103 it is.
Drivability good?
Old 11-08-2018, 08:15 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Drivability good?
Like stock
Old 11-09-2018, 12:56 PM
C5-VERT
Support Corvetteforum!
C5-VERT's Avatar
Cruise-In IV Veteran
Katech 103mm on my G1Pro intake for my Procharger nothing but positive to report. Thought I may have caused idle issues but that was a restrictive filter Procharger sent me. Soon as I put a big green filter on it’s idling fine. The Katech TB is beautiful also a nice billet piece. I know that sucker let’s a lot more air in just look at it side by side.
Old 11-09-2018, 01:32 PM
robert miller
Default ttt
Man that looks bad azz I know back when the big 102 t.b. came out that thing was a big PITA to get the driving around town worked out. Had one on the c5 set up & had to pull it off due to that reason. Glad to see stuff got works out on some in here I know a few weeks ago a guy in here was selling his doe to this problem. But again a lot has to due with tuner r so many so call tuners.. Robert
Old 11-11-2018, 07:02 PM
C5-VERT
C5-VERT's Avatar
Robert couldn't have said it better myself it's all about the tuner. Chris has spent some time and numerous adjustments to get mine to a point I am getting satisfied. The more radical the build the harder it is to tune in most cases. I chose Chris b/c he has so much experience with port injection and builds similar to mine. Can't say enough about the guy! It's also good to chat with ya Robert being a fellow C5'er myself! That's where my madness started and I am sure you spent some money in those days as well!
Old 11-11-2018, 08:30 PM
robert miller
Told myself wasn't going to mod this c7 on perdurance side at all. Well that when to HEL*. All new beefed up rear end axles half shaft, now new stock c.i. all forged new motor, ported heads, cam, small cam BTR stage II set up, small A/A TI blower with the smallest pulley can get, LT4 inj & pump. Call this it on the motor not even close to the c5. But with all the after market parts on this c7 should be safe around 800 plus RWHP. We will see what happens.
C5-VERT (11-13-2018)
Old 11-13-2018, 09:51 AM
3 Z06ZR1
3 Z06ZR1's Avatar
From what I saw from installing the 1.7 is a little too small for the 95tb. Where the 2300 uses the 95tb extra air and also so it fits nicely. I would buy the MAMO or Katech ported for the 1.7.
Old 11-13-2018, 09:57 AM
3 Z06ZR1
3 Z06ZR1's Avatar
The trouble with that is you run in to the big O ring if you port much at all the oring is smaller than the 95tb on the 1.7.
I did sorta like the top end with the 95 felt it did add a little top HPto the 1.7 . But it is great on the 2300.
Old 11-13-2018, 10:24 AM
douniasg
douniasg's Avatar
I was able too port match the 95mm spacer and still have the o ring . It is close. I can see if you port to much it will mess up the o ring groove.
Old 11-13-2018, 11:17 AM
BlueDevilZ51
BlueDevilZ51's Avatar
did you port the snout on the blower/ car?
To Best Big TB?
Old 11-13-2018, 12:09 PM
douniasg
douniasg's Avatar
No, just What you see. I wouldn't know how to port the snout. I just wanted the opening to be the same size as the tb. I think you would have a blade interference if you don't port match. Here is a pic before I started.
Old 11-16-2018, 10:53 AM
0JUICED1
Former Vendor
JUICED1's Avatar
The 95mm LT5 is a great option and we should have ported systems available soon. However, the 103s are crucial for big power set ups with ported blowers. It's pretty simple to tune for them, we have never had a drivability issue with one but it will need to be tuned for sure. We have seen major gains with our Jokers Chaos ported LT4 and the 103s.
Old 11-16-2018, 11:49 AM
FYREANT
I'm Batman..
Pro Mechanic
FYREANT's Avatar
What are the thoughts on TB options for big power centri blower cars?
Quick Reply: Best Big TB?
