Engine vs chassis dyno numbers
Has anyone had comparable figures between an engine dyno and a chassis dyno for the same engine? Just curious how much is lost from the drivetrain ? I’ve heard 12 to 18% and wondering if there may be some real world figures out there?
Received 3,087 Likes
12-13% for the manual transmission
15% for the automatic
Some things to consider:
- STP vs. SAE
- measured vs. unmeasured losses
- correction factors
- unlocked vs. locked converters
- requested and real AFR
- requested and real timing
- etc. etc.
Logs from the dyno runs are essential be be able to compare any dyno runs.
Without those provided, comparing is pretty useless.
Just my 3 cents.
- STP vs. SAE
- etc. etc.
Just my 3 cents.
Blue line locked Red unlocked
It isn't a set percent. It is a percent+fixed number, depending on drivetrain.
Kind of a pointless thing to chase down anyways. Seen a rock crawler do 900hp on engine dyno, then 600rwhp on a dyno.
Seen a c6z lose 25rwhp just swapping wheels/tires. Plus dyno to dyno variation, dyno type, etc etc
Figure anywhere from 10-40% or set number to spin certain parts + percent for friction/pumping/etc losses.
Very pointless exercise.
