Recommended poly motor mounts
Old 11-13-2018, 10:17 AM
Mrbluedevil88
Mrbluedevil88's Avatar
Default Recommended poly motor mounts
What do you guys recommend for poly motor mounts?
Old 11-13-2018, 10:29 AM
windyC6
windyC6's Avatar
I didn't realize there were a bunch of choices. I mean isn't poly...poly ? I'll be interested in hearing some of these responses.
Old 11-13-2018, 10:34 AM
Bruze
Bruze's Avatar
Received 1,136 Likes on 882 Posts
Me too. Last I knew (50 years ago) they were steel and rubber.
Old 11-13-2018, 11:50 AM
pdc001
pdc001's Avatar
Poly can have different durometer. Some like it softer, some like it harder.
Old 11-13-2018, 10:33 PM
cmonkey713
cmonkey713's Avatar
Received 1,238 Likes on 909 Posts
Summit Racing has a couple of different ones for the C-6 if I remember right. Prothane has them available also, do a search for Prothane suspension components.
Old 11-13-2018, 10:49 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Hinson mounts work well.
Old 11-14-2018, 05:19 PM
windyC6
windyC6's Avatar
I may understand this for suspension parts....but motor mounts. So someone may want their motor to rock & roll more than others? Hell....back in the day all I would do was chain down the motor on the high lift side and just race on......
Old 11-14-2018, 05:33 PM
Ahrmike
Ahrmike's Avatar
Motor mounts give for a reason... Less noise to the frame, less impact damage on the block, etc...
Makes sense theres different durometers? I guess for a full race setup you'd want it as hard as possible without the engine mount point failing haha.
Old 11-14-2018, 05:49 PM
Sox-Fan
Sox-Fan's Avatar
I have not used AMT's engine mounts, but I have used some of their other products. Well engineered, well made, very well documented, and very well supported.
https://amtmotorsport.com/collection...n-motor-mounts
Old 11-14-2018, 08:33 PM
Spaceme1117
Spaceme1117's Avatar
Received 1,312 Likes on 884 Posts
I highly recommend never putting poly motor mounts. Unless, you like your car to rattle the fillings out of your teeth.
Old 11-14-2018, 08:43 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Poly mounts are not solid mounts. Hinson mounts been on my car for years and the difference is minimal. The difference in vibration from stock is so minimal that it's a non issue.
But of course it's people that have never used them who say not to.
Old 11-15-2018, 01:33 AM
pdc001
pdc001's Avatar
I haven't really seen what durometer the aftermarket companies states for this platform but my daily, Mazdaspeed3, aftermarket companies who makes poly mounts for that platform has ranged anywhere from 70 duro to 90 duro and from there it's solid engine mounts. So there are some people who like it softer than others. My buddy is more OCD about engine shaking than I am so he has opted for a softer duro compared to me.
Old 11-15-2018, 10:47 AM
windyC6
windyC6's Avatar
Why would anyone want their engine to "Shake" excessively ??.......inquiring minds must know.
Old 11-15-2018, 10:54 AM
Bruze
Bruze's Avatar
Yes ^.
And what was so bad with the old steel/rubber mounts?
Old 11-15-2018, 06:38 PM
pdc001
pdc001's Avatar
I don't believe anyone really wants to feel their engine shake excessively. Harder poly mounts will reduce the amount of engine torqueing left to right. Softer ones will allow it to flex more but it'll give you more interior comfort. There are some people who don't mind it shaking "excessively" but everyone has their own taste to as to what they consider excessive. For my Mazdaspeed I do have the harder duro and I don't mind the light shaking at the steering wheel and clutch chatter. I've driven my buddies H/C/I with the hinson mounts and it shakes at idle. He would prefer it toned down a bit but it never bothered me driving it. To each their own.
To Recommended poly motor mounts
Quick Reply: Recommended poly motor mounts
