Rochester EFI plans
Received 1,283 Likes
Rochester EFI plans
Yep, I am still thinking about this.
I have made arrangements to purchase a nice plenum, plenum lid, base adapter (manifold), as well as some air meter parts and some other odds and ends.
I still want to "hide" the actual injectors inside the plenum, and have original injectors in the normal position that do nothing.
I have sketched out a "Plenum Injector Module". This will be made out of aluminum, with a removable top, and will be air tight when assembled. It will fit inside the plenum, and be attached (most likely to the plenum lid bolt holes).
The fuel supply and the wiring for the injectors will come up through the bottom of the plenum, or some other existing opening in the plenum.
This Plenum Injector Module will be as narrow as possible as still fit injectors in it. The injectors will be tilted at an angle, and pointed into the appropriate runner.
One question to be addressed is how small (physically) of an injector can be used and still supply the appropriate amount of fuel to the engine.
Anyway, here is my sketch of the Plenum Injector Module.
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
Ed, won't that represent a significant restriction to air flow?
Pro Mechanic
Received 1,303 Likes
2023 C1 of the Year Finalist - Modified
We call the "surprises" off-nominal; the solutions bring us back to nominal.
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Why not just buy a correct 7375 or 7380 unit and bolt it on the car and go ?
I have a lot of respect for your opinions; you have definitely "been there, done that".
So, can you be more specific on why this is not going to work? There have been a lot of previous discussions, I need some help separating the facts from the opinions.
Many thanks in advance for your assistance.
Ed
I thought about it, and I still think about it.
I have made arrangements to purchase a nice used (but still needing cleanup, etc.) plenum, plenum lid, base adapter (manifold), nozzle blocks, piezometer ring, spider, venturi diffuser, a couple of tubes, and a bag of small parts. I "believe" these parts are for a 1963 system. There are no fuel meter parts, and no distributor.
The only parts needed for the EFI conversion are the plenum, plenum lid, and base adapter (manifold).
I continue to search for fuel meter parts, and a distributor (at a decent price).
I am not in a hurry, and I still want to explore the EFI conversion path.
By the time I am all in on a restored Rochester FI unit, including distributor, but not the air cleaner setup, I am looking at about $12,000 to $14,000. And the issues that come with Rochester FI systems (tuning, percolation, etc.) are still there. This is not a big deal, but it does factor in.
I thought about it, and I still think about it..
I think your cost estimate is too high by, oh, 50% or so. With patience, you can find a rebuildable FI unit and have it rebuilt (or better, do it yourself) for significantly less.
Tuning isn't tough. As far as I"m concerned, this is a non-issue.
Fuel perc, well, yes, in Huntsville you might experience this if you try to drive in stop/go traffic. As long as you are moving, fuel perc does not happen.
Jim
St. Jude Donor '07
Bill;
Ed
Ed
as Jim and I have said on several occasions, you simply cannot crowd all that stuff inside the doghouse and have sufficient air flow; kinda sorta like running with the choke closed to some degree. it would 'run', but it will run like crap... the guy (my apology for the senior moment and not remembering his name...) from Michigan did a masterful job of hiding the EFI stuff.
someone else (again, an apology...) hid a single fuel rail under the doghouse and only had lines running out to the injectors; again an improvement to the in-your-face visibility.
the injectors are going to have to be visible UNLESS you can find a way to mount them inside (your plan) over each intake runner, BUT then bracketry and the injectors themselves are going to block air flow. kinda a win/lose scenario. and then there is the airmeter…. it isn't gonna fool anyone as it only vaguely resembles a FI air meter; BUT ya gotta have one
if you guys can put a man on the moon, then maybe you can do this too; but I have to say i'm not too optimistic.
Bill
64's Rock!
What computer control are you using? I used a diy solution awhile back for another car that worked pretty well. Megasquirt is the name. At the time I soldered together my own controller, but I think you can buy assembled controllers at this point.
It may not be necessary to do this. One of the things that I am investigating.
OK, I sorta get that. Unless you use injectors which are rated to be explosion proof (like used in TBI systems, for example), you'd have a risky situation with active injectors suspended in free air.
