63 Stabilizer Bar
Old 11-14-2018, 12:23 PM
PappyPete
3rd Gear
PappyPete's Avatar
Default 63 Stabilizer Bar
I recently realized that my 63, which I recently did(on road3 summers, from 2016) a complete body off resto mod on, has standard front springs and shocks, but the stabilizer bar I put back was an F41, 15/16" bar, instead of the standard 3/4" bar. The rear suspension is a standard leaf, with standard shocks, and the engine is a 327, with 4 speed. Can anyone tell me if the ride is stiffer/harsher with the thicker stabilizer bar, or just that the car has less "lean" during turns, but a similar ride?
Old 11-14-2018, 03:59 PM
jim lockwood
jim lockwood's Avatar
Received 6,529 Likes on 3,004 Posts
C2 of Year Finalist (track prepared) 2019
That 15/16 bar is 2.44X as stiff as the 3/4 bar. You'll likely notice that. The big effect, if you push your car to the limits of tire grip, will be that it will have more pronounced understeer. That is, instead of turning, the front end will just plow right off the road
Old 11-14-2018, 04:10 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
unless there is differential movement (up and/or down) of each wheel there will be no difference in ride harshness; if the wheels move up and down at the same time (such as a dip in the road) there will be no difference. AND I doubt you will notice much difference with differential movement (such as a bumpy road); the value is in counteracting 'lean' while cornering when there is a potentially large difference in respective wheel movement.
so, as far as harshness, don't worry about it
Bill
Old 11-15-2018, 07:18 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Which means you'd better get familiar with the new handling characteristics of the car after this change if you push it.
Stay within your skill level....
Old 11-15-2018, 08:33 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
Jim is right, if you're going to run the big bar then you need to add the rear bar to correct for the understeer.
Bill
Old 11-17-2018, 11:13 PM
PappyPete
3rd Gear
PappyPete's Avatar
Thanks for the feedback
i have a question on the rear stabilizer bar. If I’m not into pushing the car hard, just sunny day drives in the country and highway drives. Will the heavy front bar make that big a difference in handling under those conditions, without the rear bar?
Old 11-18-2018, 01:02 AM
Factoid
Factoid's Avatar
Received 5,554 Likes on 2,797 Posts
No, you will be fine.
Old 11-18-2018, 07:33 AM
jim lockwood
There is handling and there is ride comfort. The two are not the same.
Handling describes what the vehicle will do at the limits of tire adhesion. You already know how that large bar will affect handling.... the car won't want to turn.
Ride comfort is, well, ride comfort. As WMF62 pointed out, as long as both front wheels see the same disturbance at the same time, the bar will have no effect. On the other hand, if only one wheel encounters a bump or a pot hole, I believe you'll feel that in the car as additional ride harshness. How much and will it be tolerable? You'll have to judge that.
Jim
Old 09-27-2022, 04:20 PM
Paulami
Paulami's Avatar
The sway bar on my '56 does not have a notch, if I understand that correctly, and it is 11/16". Would that already be a later bar? If not, what diameter is the '62 bar?
Old 06-05-2023, 09:45 PM
QIK59
Support Corvetteforum!
QIK59's Avatar
Exactly - your car will feel more responsive - less lean.
Road racing will be another story
Old 06-05-2023, 09:54 PM
QIK59
QIK59's Avatar
Default NOTCH (sic) front bar
That IS the early "notched" bar that you have - the term "notch" in this useage is VERY misleading - the bar has an offset not a notch per se.
The 1960-1962 front bar is 13/16" diameter and would be a good improvement
To 63 Stabilizer Bar
