Headlight motor removal question
Old 11-14-2018, 05:11 PM
STRMLNE
STRMLNE's Avatar
Default Headlight motor removal question
How are ya'll getting to the nuts on the other side of these bolts? I was able to get the front one out but these other two appear to be pretty difficult. Is there a trick? Thanks.
Old 11-14-2018, 05:32 PM
GCG
GCG's Avatar
It's doable and it helps if you don't have Popeye's arms and have a little dexterity . What I did was to remove the black plastic bezel (I didn't have to touch the painted cover) and then detached the linkage lever from motor shaft's end. After doing that, the bucket needs to be supported from below in the open position (I used a plastic rod I had around that had the right length), but since it can now be opened a bit more, it leaves you a little more room to get to those nuts.
I found it faster and easier than the more traditional method of removing the whole assembly.
Old 11-14-2018, 05:46 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
I installed the brass gears in my motors, a few years back. As I recall, I removed the entire headlight assembly in a single unit, and then separated the motor from the frame, on my workbench.
Old 11-14-2018, 06:01 PM
STRMLNE
STRMLNE's Avatar
Thanks. I removed the plastic shroud and the painted cover. Still a tight fit down there. Damn.
Old 11-19-2018, 09:20 PM
aj98
aj98's Avatar
IIRC, I used a 1/4 drive socket on one side and a small open/box end on the other
Old 11-19-2018, 10:07 PM
STRMLNE
STRMLNE's Avatar
Thanks. Got it taken care of. Major pain that’s for sure.
Old 11-20-2018, 06:55 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
I agree....remove to bucket and place on a bench.
To Headlight motor removal question
Quick Reply: Headlight motor removal question
