Have to push door open button twice to get out
2017 Z06 A8.
this seems to have started recently (past couple weeks). I push once and there is lock noise and door moves slightly but will not open. I have to push the button a second time to be able to open the door. Car is in park with engine off at this point. I also notice on entering car, when I press the pad in door handle it makes lock click noise 2-3 times. Anybody else seen this?
I tried open door just after getting in and after turning on engine and both of those times it opened right away. Maybe its related to auto locking after moving.
On your first observation (getting out) this may be a stretch but for preventative reasons I'd have my battery load tested. Can't hurt.
On your second point, when I squeeze the door pad getting in I hear the bolt lock for the fuel door actuate several times, always. Not sure if this is normal. I'll be following this thread for the second point.
2017 Z06 A8.
I'm on the batter tender and it cycles between charged and charging. So i assume it doing it's job.
Also replaced batteries in the Remotes, but didn't seem to have any affect.
During unlocking I get several clicks, but I think they are from the fuel door unlocking and not the vehicle door itself.
Received 5,188 Likes
"... i assume it doing it's job" Assume nothing, check your battery and connections to be sure.
Received 2,639 Likes
I had this happen to me several times in one day. So, I thought I would pay attention to see if I could figure out what was happening. I found I was pushing on the door (out of habit) at the same time I was hitting the button. I do this in my other vehicle that have manual latches. I made sure I stopped what I was doing, and luckily the door stopped what it was doing. I figure I was putting some pressure on the latch causing it to hang instead of moving as it should.
Disclaimer: This was my experience only. YMMV. Good luck.
Been happening pretty reliably now this past week or more. Getting in and out. Im being careful to not push or pull on door while pushing button. Whats strange is I releases enough on first push to open the door slightly. Maybe im not fast enough?
I cant buy the weak battery theory since it would fail cranking long before it fails to release lock. At least I would expect that to be the case.
