WTB: Drive side mirror
If you have a 2lt or higher make sure one you get is from the same so it has auto dimming not found on the 1lt trim level. I think it has the memory feature also. I have a black one from a 2lt for $165 shipped if you are interested.
Man, thank-you so much. It was the right paint code and 150 bucks is a steal. Problem is that it's the light sensitive mirror which mine is not. But I am rolling the dice
and will try it. I figured a mirror is a mirror and as long as the pigtail is correct it will just not change color and I'll be good to go.
