door lock doesn't open when engine is turned off
Hello
Until today, when I turned the key off, both doors would become unlocked. Now tonight, only the passenger side unlocks when the key is turned off. Any idea what happened? I have to unlock the driver's door manually now.
Thanks for any advice!
Try unlocking.locking with the fob. If it won;t my guess is the locking motor or some electrical component has failed. If it does lock/unlock from the fob I would try I would try a little lube
Received 19,289 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
I had this issue, they door would lock, but not unlock automatically. I replaced the relays on the board in the door, there are 2, and all works great now. There are many write-ups about how to do it.
I had the same problem about a year ago. After doing some troubleshooting and reading threads, I sent my door module control off to have the relays replaced. It's worked perfect ever since.
