2000 Hvac dead
Old 11-15-2018, 09:51 PM
Rob586
5th Gear
Rob586's Avatar
Default 2000 Hvac dead
I've have a 2000 vert, jumped in it after being on vacation for a week and the hvac head unit was black & unresponsive (not dim due to age). Searched the web for a few hours the next day on possible fixes, # 18 and #27 fuses are good, G202 ground has zero corrosion, shook the accordion tube between the doors. I even pulled the ignition switch (following Bill Curlee's instruction) and found a couple of burnt contacts, cleaned them up with 600 then 1000 and rubbing alcohol and still nothing. I am thinking the unit itself is bad. If anyone has recommendations it would be greatly appreciated. Fortunately enough summer is over down here in south Florida.
Old 11-15-2018, 10:46 PM
mmartinez
mmartinez's Avatar
Most likely problem is resistor's on hvac control board not making good contact to circuit board, This is a known problem, unit has to be removed and resistors resoldered or hvac head unit replaced,
Old 11-16-2018, 07:23 AM
Rob586
5th Gear
Rob586's Avatar
Thanks, I'll check it out
Old 11-16-2018, 05:55 PM
Rob586
5th Gear
Rob586's Avatar
Would you know of anywhere to send the unit for repair?
Old 11-16-2018, 09:23 PM
mmartinez
mmartinez's Avatar
No clue, but maybe somebody on the forum might, re-post with hvac controller repair shops.
Rob586 (11-16-2018)
Old 11-16-2018, 11:03 PM
STRMLNE
STRMLNE's Avatar
Absfixer.com May be able to help you
Old 11-17-2018, 04:12 AM
Mickeyrx70
Mickeyrx70's Avatar
Try c5led.com, Dave’s Corvette Illuminations. He repaired the lights on my HVAC controller a couple years ago and did a great job. Fast turnaround, fair price, and he guarantees his work. If the controller itself is bad/can’t be repaired, he may even have a replacement. His site lists his phone number, so you can speak with him directly with any questions.
To 2000 Hvac dead
Quick Reply: 2000 Hvac dead
