Replacing 85mph speedo with 140mph speedo
Has anyone got any information on can i replace a factory 85mph speedo on a 81 corvette auto, with a 140mph speedo from a 82 model corvette, and will it read correct, is there any modification required, also it has a broken needle can i just swap it with the 85 mph one? thanks
79rallypack (11-19-2018)
I believe you cannot install a 140 mph speedometer in place of an 85 mph one and have it read correctly. When my 1980 was new, the dealer replaced the 85mph one with a 140 mph one. They installed an adapter of some sort in the speedometer cable. I was not the original owner so am unable to verify why this adapter was installed, but I assume it is to make the 140 mph one read correctly. I maybe able to find the part number if interested. The other alternative is to send your 85mph speedometer to a shop that converts them to 140 mph and recalibrates them so it reads correctly.
To clarify, are saying you can install a 140 mph speedometer in a corvette that came with an 85 mph and it will read correctly, without recalibration?
Only the odometer would not be accurate?
i believe the standard is speedo cable will spin at 1000 rpm at 60 mph. what your needle and odometer shows is based on that standard..
so yes, swap away..
but beware you are changing an odometer also and you might run into legal issues if the miles of the 2 devices are different.. at least disclose this at sale time.
so yes, swap away..
so yes, swap away..
so yes, swap away..
your also not trying to mislead or defraud, your after functionality, not trying to pass off a car as 5k miles
I sent mine to Roger Scott - Corvette Instrument Service, ( corvetteinstrumentservice@att.net ) in Florida. he changed mine to 140MPH and I kept the same mileage. The calibration for the speedometer is magnetic in the head itself, the plastic gear in the transmission matches the revolutions to the correct rate of speed. My trip odometer was not working properly but he was unable to repair that as the parts for the trip odo are NLA.
I have an '81 and tried this SWAP. No go without recalibration.
I sent my 85 mph speedo into Corvette Central. They have a speedo service.
They changed the face to a 140 mph speedometer and recalibrated it.
I would highly recommend having a speedometer service calibrate the combination.
The 140mph speedo that i purchased has a broken shaft that the needle is attached to (i think it is called the "speed cup shaft") does anyone know where /who i can get one of these from, i live in Australia or will i have to send it to the states to get repaired.
No offense, but I used to have a Suzuki GS1100 E with an 85 mph speedo. At first I disliked it, but I grew to prefer it after a while. The amount of sweep in the normal driving range 55-80 mph was twice as much as on a 160 speedo, much more precise and easy to read. And if I did venture to stupidly exceed 85, using my tach, I could figure my speed. It's just an ego thing in my opinion.
I sent my speedo to redline. They recalibrated and refaced to 140 mph . Still working fine after 8 years
https://www.redlineg.com/
not sure if it's any good to you but I have a 1977 model Speedo sitting here no longer needed , it's complete so the shaft is there if it's practicle to transfer. You can have it for parts if you want.
Just confirming that your 80 Vette had a 85 mph speedo, and after you put it in the 150mph speedo you did not have to change the speedo drive in the gearbox. by the way i like your 240kph speedo
Yes i had the 85 mph one, redline calibrated it to work with the TH350 trans and 3.08 gears. Then i swapped out the 3.08 gears to 3.55 and had to change the small gear in the trans to the grey 21-22 tooth speedo gear to be correct. All good.
