C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
I have 91 heads with ported 90 housings
Old 11-17-2018, 01:54 PM
oldpro
oldpro's Avatar
Default I have 91 heads with ported 90 housings
What do I have to do to the pcv system on the injector housings to make the pcv system work correctly .i looked at a couple of threads but really can't make heads or tails out of it sorry for the dumb ? Could someone share what I have to do to make this work . Thankyou
Old 11-18-2018, 04:51 AM
oldpro
oldpro's Avatar
Go the answer I needed
Old 11-18-2018, 05:49 PM
ccmano
ccmano's Avatar
I see you got your answer. I have the same set up. Conventional wisdom is that this combination will work without modifications since both the heads and the IH’s have the same restriction. I am not having any issues. Recently I have noticed that Marc Haibeck is recommending that the IH restrictions be opened up somewhat to at least 3/4 in. Makes me wonder what he has noticed or experienced to make that recommendation.
H
Old 11-19-2018, 12:21 AM
Dominic Sorresso
Dominic Sorresso's Avatar
Where did u see that Hans? I have IHs off car so could make change if necessary.
Old 11-19-2018, 07:07 AM
A26B
A26B's Avatar
1990 model heads were machined to 3/4" diameter for the PCV vents, but too much oil was being passed through the PCV system. The fix was to install a baffle/washer with abut a 5/16" hole in the center, into the injector housings. For 1991 & later models, they reduced the 3/4" holes in the heads to 5/16" and eliminated the machine work & labor to make & install the baffle/washers in the injector housings.
If you have 1990 injector housings on a 1991-2, you can just remove the 2 baffle washers from the injector housing. No drilling or other modifications required.
There is a free, detailed tech data sheet with photos available on Jerrys Gaskets web site that explains all the differences between injector housings.
Old 11-19-2018, 09:00 AM
Dominic Sorresso
So Jerry, any idea why Marc would be rexommending going to 3/4”?
Old 11-19-2018, 09:58 AM
ccmano
ccmano's Avatar
Dom,
Marc states this in the following thread, post number 5.
http://www.zr1.net/forum/showthread....jector+housing
Jerry,
To be clear, many past posts, even your spec sheet, which detailed the IH variations and possible combinations a few years ago, stated that a 90‘ injector housing on a 91‘-92’ head does not require modifications.
H
Old 11-20-2018, 02:01 AM
A26B
A26B's Avatar
I don't know what Marc is thinking. I would imagine he is not a fan of two, in-line restrictors and is simply opening up the baffle/washer in the 1990 heads to make the flow path more like the 1991-95 design and nothing magic about the 3/4" sizing. The modification made for 1991-95 models all had the restrictor hole drilled in the head and a cast-in PCV port (about 1") in the injector housing.
Old 11-20-2018, 02:17 AM
A26B
A26B's Avatar
Originally Posted by ccmano
Dom,
http://www.zr1.net/forum/showthread.php?t=28608&highlight=Injecto r+housing
Jerry,
H
Hans,
You are correct, I don't think it's necessary to modify or remove the PCV baffle in the injector housing when used on a 91~92 cylinder head.
We're not talking about high pressure or high flow rates that would be cause for concern about a back-pressure increase of any detrimental effect. The entire purpose of the small hole is to keep oil in the cylinder head while providing a path for the fresh air inlet flow to each cam cover. It does not double the restriction.
Regardless of what my personal opinion is, removing the baffle/washer in the 1990 injector housing or drilling a 3/4" hole certainly isn't going to be detrimental.
Old 11-20-2018, 08:38 AM
Dominic Sorresso
Even after playing w these motors for 10+ years, I never noticed until now that only the back vent bosses are drilled. The one in front, both on the head and IH are non functional.
Also, I’ve always had what appears to be “grit” coming from the plenum.
To I have 91 heads with ported 90 housings
Quick Reply: I have 91 heads with ported 90 housings
