How big of rims can you before you run into problems
Can you put 19 20 combination and are the tires alot more money and does it create some problems, are the C7 a 19 20 combo ? and what seems to look best..... I think I was looking at one with a OEM C7 set up and it looked good.
There seems to be alot of wheel tub area left with the stock set up, just wondering how far you can push it.....without drivability problems
Thanks....
Thanks....
595R
19 x 9.5 ET 59 w/ 1.5" outer lip
19 x 11 ET 48 w/ 3" outer lip
275/30-19 front and 295/30-19 rear
I have 19s all around-people have gone bigger though.
I run 20's all around
Rear 10.5" 305/25/20
Front 10" 295/25/20
Even with the low profile tires the ride quality is better than I thought it would be, coilovers & drop spindles help, I did my own alignment & even with the wide front tires I do not get any wander or tramlining, and the handling is fantastic.
If I was to make any changes in the future & I find a new wheel combo I like, I would run a 21" rear & 20" front combo.
Front 10" 295/25/20
Night Owl for life
Received 3,247 Likes
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Received 1,870 Likes
Front 10" 295/25/20
Front 10" 295/25/20
Received 3,812 Likes
Thanks....
Thanks....
I will admit these cars look best with a staggered setup as the rear wheel well opening is larger than the front, so nothing wrong with 19/20 or 19/18, it all depends on what you really like, you can even run 18/18 or 19/19.
I have 19's on all corners... 19 X 10 on the fronts and 19 X 13 on the rears, with 345 / 35 / 19.
Yello95 (12-17-2018)
Evil-Twin (11-21-2018)
