[C2] Onyx cover
2021 C2 of the Year Finalist - Unmodified
Onyx cover
For those using one: what do you do about the antenna? I put a tennis ball on the end and stretched the cover over it. I am reluctant to make a hole fearing that it may start unraveling. Anyone poked a hole?? If so, how did it work?
Great cover otherwise.
Regards,
Jerry
Regards,
Jerry
Received 6,943 Likes
2015 C2 of Year Finalist
Dad has one for his 67. We just remove the antenna before putting the cover on
My understanding is that removing the antenna is a pretty big job. Am I wrong? Can the mast be removed w/o disturbing the power mechanism? A quick search of the forum didn't turn up anything.
Regards,
Jerry
Regards,
Jerry
I don't know what year car you have. On a 67, it's easy because the antenna is fixed-mast and unscrews from the base very close to the deck line. For earlier cars where the mast retracts but cannot be easily removed, most of the cover vendors supply the cover with a plastic clip on grommet. The idea is, you cut the hole where you want it, and then clamp the round grommet in place so the antenna has a place to go. I think I might have an extra one of those if you need it, PM me and I can look.
On a 67 the mast just unscrews. Now on a 65-66 I can’t remove it. The car cover did come with a grommet just for this problem
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,329 Likes
That’s one thing I like about my VettesUnderCover covers. Both were ordered with antennae hole installed and nicely stitched so no more messing with chopping a hole in your new cover.
