***Radioflyer Innovations Black-Friday Sale - ALL WEEK***
Supporting Vendor
You've been waiting for it, and here it is: Radioflyer's Black-Friday Cyber Monday sale on select items. We're running these prices ALL WEEK starting Monday Nov 19-Monday Nov 26. These prices are even better than our 10-year Anniversary sale with some items more than 20% off. If you've been on the fence, now's the time to get top-shelf products at rock-bottom prices.
C6 Bi-LED headlights
These incredibly popular headlights are a fantastic upgrade to the aesthetics of your C6. When you buy your lights from Radioflyer, you get Three major upgrades not found anywhere else:
1) Our Correct-DRL/Signal function harness is hard-wire into your headlight harness for plug-and-play operation ensuring the White bar is the DRL and the Amber part is the turn signal.
2) You get a set of our high-output LED fog lights FOR FREE!
3) Our headlights retain the flash-to-pass high beam function during daytime (headlights from other suppliers do not)
This week only just $1,100! Order here: https://radioflyerinnovations.com/sh...led-headlights
With included fog lights
Daytime Running light Function.
Night flyer package for C6: The All-inclusive HID/LED conversion for your bone-stock C6. This kit upgrades every exterior bulb on your car to Radioflyer Quality lighting including Morimoto XB HID low beam bulbs, High output LED High beam and fog lights, and Cree LED bulbs for every other exterior bulb on your car.
This week just $575! Order here: https://radioflyerinnovations.com/sh...or-c6-corvette
Complete C6 LED conversion:
Tired of dated incandescent bulbs? Convert every major bulb on the inside and outside of your car (excluding headlights and fog lights) to our Powerful Cree LED-chipped bulbs (colored to match their position where applicable) This week just $240! Order here: https://radioflyerinnovations.com/sh...ersion-package
DRL/Signal comparison
Tail light bulb comparison
Reverse light Comparison
HID/LED headlight upgrade:
HIDs are nice, but they can be brighter, especially if your aging bulbs have already started to fade. For the same price as a set of OEM HID replacements, you can upgrade to Radioflyer's 55w HID system and LED high beams for truly phenomenal headlight output. Perfect for rural driving.
This week just $210! Order here: https://radioflyerinnovations.com/sh...or-c6-corvette
Low beam comparison
Low beams on road
Bi-LED headlights Correct-Function harness
Okay,,, you got your Morimoto Bi-LED headlights from another vendor, but now the DRL doesn't work the way you want and you have to run a goofy harness to the fuse box or drill out your dash for a switch and it still won't work right. Not anymore, Radioflyer's "Correct Function" harness provides a simple plug-and play solution that makes the White LED bar the DRL and the Amber LEDs the turn signals without all that hassle. These harnesses also restore the high beam flash-to-pass function.Order your set for just $100 this week only! (Lowest price ever) https://radioflyerinnovations.com/sh...nction-harness
C6 White DRL harness
For nearly two years, Radioflyer Innovations has provided the conclusive plug-and-play solution for having White Daytime running lights and Amber turn signals. Completely weather-proofed and there's no risk of incorrect polarity. Order your set for $95 this week here: https://radioflyerinnovations.com/sh...or-c6-corvette
C6 interior kit:
Ever tried to see inside your car at night? Odds are you wished you had a flashlight. No need for that with Radioflyer's Interior conversion kit. Powerful Cree XP-E LED technology will light up your interior with enough light for surgery. Makes a great stocking-stuffer
Order your kit for just $75 here:https://radioflyerinnovations.com/sh...conversion-kit
C6 resistor pack for LEDs:
Want LED turn signals without hyperflash, our resistor pack harness maintains the factory flash rate while providing a safe and hidden place for the resistor. These will work with ANY LED turn signal bulbs. Order for just $60 here: https://radioflyerinnovations.com/sh...-pack-for-leds
C6 LED fog lights
Ditch those dull halogens for our powerful LED fog light bulbs. They not only increase output and in a pleasant color, but the chip-set orientation on the bulb not only increases the width of your pattern making it easier to see the sides of the road up close. (Makes a Great stocking stuffer)
Order yours for just $50 here: https://radioflyerinnovations.com/sh...upgrade&page=2
HAPPY THANKSGIVING
Low beam comparison
Low beams on road
C6 interior kit:
C6 LED fog lights
HAPPY THANKSGIVING
Any great deals on C5 lowrise headlights? I'd like to upgrade my '02 coupe first, then do the GS next year. Only so much $ in the mod budget!
Supporting Vendor
Figured I'd respond this thread since there seems to be some issues with the Morimoto "fix" harness not working quite the way everybody had expected for the Gen1 Morimoto bi-LED headlights.
George (Radio Flyer) sent me one of his harnesses a month or so ago and it works great. There is a separate harness for each side. Its about a foot long. Two plugs ... one into the headlight and other into the OEM harness. No need for the fuse tap that came with the Gen1 Morimoto lights. It works exactly as advertised. White hockey stick is the DRL. Ambers are the turns/flasher. White hockey stick goes out when amber comes one, then comes back on when amber goes off. Flash to pass works without the low-beams being on. No hyper flash. Exactly like the C7 works. No fuse tap. Everything is tucked under the headlight so you never see anything. The harness and plugs are first-class parts.
I notice it is on sale in this thread ... if you want C7 functionality for your Gen1 lights with no extra fuse taps, etc., get this one. It works.
Roadhog1956 (12-29-2018)
Supporting Vendor
If you're referring to the night flyer package or the HID/LED upgrade, no. These are bulb replacements only (which makes installation MUCH easier) The Projectors are decent quality and with a good light source provide excellent visibility at night on even the most rural highways.
Very tempted at this price point for your harness for the Morimoto lights seeing as how Morimoto royally fucked up their harness.
How do the resistors mount to the car?
Supporting Vendor
