[C2] Hood Alignment
Old 11-19-2018, 03:03 PM
AJO1958
3rd Gear
AJO1958's Avatar
Default Hood Alignment
I put an original ‘63 hood on my 63 (which for some reason had a 64 hood. Driver side lines up perfect but at hinge and at top latch the hood is about 3/8 of an inch higher than fender body. Center on the passenger side is good. Hood is was taken down to fiberglass and didn’t look to have issues. Is it common for hoods in that era to have some such gaps? I can take a shower out from hinge but the center is low and latch is still high. I can post pictures if needed.
Old 11-19-2018, 03:09 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
You are confusing the terms, "flush" and "margin". Which is it?
How did the '64 hood fit? The '63 hood should fit the same unless someone has done some midnight fantom bodywork to either the hood or the right side of your car.
Got any pictures?
Old 11-19-2018, 03:51 PM
woodsdesign
woodsdesign's Avatar
There is some adjustment on the latch by the firewall. Also, did you check to see if there were shims under the hinge? I have seen people sand down the fiber glass under the hinge or even mill a little off the bottom of the hinge. Pics would be a big help.
Old 11-19-2018, 07:49 PM
AJO1958
3rd Gear
AJO1958's Avatar
Therr is one shim which i can remove but that would make center portion be below fender. The prior hood fit flush to body line with the fender. Gap down by hinge is like 1/4 inch or more. Top by latch is smaller. No midnight body work to my knowledge. . Attaching pictures.
Top passenger side by latch
Bottom passenger corner by hinge
Same shot by hinge w/o reference finger
Center where hood is flush with fender
Old 11-19-2018, 09:24 PM
Greg Hollowaty
Greg Hollowaty's Avatar
JAO,
You can lower the front edge of your hood by adding a shim under the edge of the hinge that is the toward the firewall. I have used some A arm alignment shims that are available in a verity of thicknesses and that will allow you to tune the downward movement. Works like magic - no milling or sanding required. Found this trick right here on our forum.
Old 11-19-2018, 10:29 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,615 Likes on 1,947 Posts
I don't think a hinge adjustment is going to correct that front corner edge of the hood. The hood corner fiberglass is just way off of the contour of the surround at that corner. The hood appears to have much less forward and lateral side curvature and is just too flat to flush out with the surround. At the upper, latch area it would seem some of that offset ould be taken out with adjusting the latch - but that would pull the center part of the hood side down below the fender. Most of the time a little irregular fit on the side of the hood/fender gap can be corrected by splitting the bond seam of the fender gutter to the inner wheel well, shimming the fender it to match the hood and then injecting bonding adhesive back in the joint. In this case that doesn't look like the solution. That hood is going to take some serious body work to make it fit right IMO.
Old 11-20-2018, 12:00 AM
Dougs63
Dougs63's Avatar
2018 C4 of Year Finalist
2016 C4 of Year Finalist
2015 C4 of Year Finalist
I'm currently working a similar issue with my '63 Convert. Seems to be a common problem with '63 hoods fitting flush to the top hood surround.
Mine sticks up about 1/8" on the sides, around the middle of the hood surround. Front edge and back edge seem to fit relatively good, by comparison.
Looking at applying heat to possibly re-shape the hood or possibly separating skin from the frame and re-bonding in the correct position.
Fortunately, I'm working with raw fiberglass - no paint.
Old 11-20-2018, 05:05 AM
tbarb
tbarb's Avatar
I am going to guess body work at some point in the cars history. If you adjusted it flat to 1/16" low at the firewall it would probably be high all the way down to the front hinge corner. The fix is not In the hood but in the inner fender to surround panel bond.
Old 11-20-2018, 06:50 AM
DansYellow66
You want to adjust the hood to fit at top and bottom and separate the bond of the surround fenders to the inner wheel wells and shim the middle area of the fenders to flush with the hood - then re-bond.
Old 11-20-2018, 06:57 AM
DansYellow66
Another possibility is the lower corner down by the parking light took a good hit sometime in it's past which will tend to fold the corner down and under to various degrees depending on how hard it was hit. If they don't get the upper surround corner jacked back into place before doing the fiberglass work on the lower corner around the parking light it will end up like that. In other words the hood is OK but the corner of the surround is rolled down by prior damage. Should be apparent from standing back and looking straight on at the car. Sometimes the leading edge of the wheel opening is pushed back closer to the tire to or has been trimmed off. I had a 66 years ago that had this issue on the driver side from an incident that damaged the parking light area.
Old 11-20-2018, 07:32 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I never heard an answer to MikeM's question... How did the '64 hood fit ?
If the nose had been "folded down" in a hit I would think it would be reflected in the headlight bucket fit -- which looks pretty good IMO...
Old 11-20-2018, 08:21 AM
pop23235
pop23235's Avatar
Received 1,019 Likes on 679 Posts
Recommend you use a straight edge to measure the hood curvature on the driver side and compare it to the hood pass side. If the same, you have a surround issue. If different, as in flatter on the pass side, you have a hood issue. Then proceed from there.
Old 11-20-2018, 08:36 AM
SJW
SJW's Avatar
Received 1,379 Likes on 915 Posts
Might be easier to transfer the cookie sheets to the '64 hood, and call it a day?
Live well,
SJW
Old 11-20-2018, 08:48 AM
Frankie the Fink
Army
Live well,
SJW
I thought about that but didn’t know if it had been done before. And if the 64 hood fit is bad it’s a non-starter anyway.
Old 11-20-2018, 09:15 AM
65 Pro Vette
65 Pro Vette's Avatar
Received 1,041 Likes on 573 Posts
C2 of Year Finalist (appearance mods) 2019
You can’t transfer of the cookie sheets onto a 64 hood without it looking seriously pathetic. There’s a second recess in a 63 hood to drop the pans flush with the hood. Believe it or not if you store a hood for many years it can change shape depending on how it was stored either too flat for two curved. My guess is that hood was stored Wrong or it is another fine reproduction. An original 63 no hit body and an original 63 no damage hood will fit together perfectly. If everything was stored correctly. When the cars have had damage a good body shop will make the hood fit the car no matter where the damage was. And if you try to put a different hood onto that same car thy usually do not fit. There are many Corvettes out there that have that same problem because of poor repair.
Frankie the Fink (11-20-2018)
Old 11-20-2018, 09:22 AM
woodsdesign
Originally Posted by 65 Pro Vette
" Believe it or not if you store a hood for many years it can change shape depending on how it was stored either too flat for two curved. My guess is that hood was stored Wrong or it is another fine reproduction."
So, how is one supposed to store a hood? I have my original hood stored in the closet standing on the firewall edge. It has been there for years. Just wondered because it fit the car perfectly when I took it off for a BB hood.
Old 11-20-2018, 09:23 AM
Frankie the Fink
Army
Yeah - moving the cookie sheets over is prob a non-starter as well...I'd forgotten about the "double depression" as shown on this 63 hood.
To Hood Alignment
Old 11-20-2018, 11:59 AM
SJW
SJW's Avatar
Yep, disregard that suggestion!
Live well,
SJW
Old 10-31-2020, 06:17 PM
OldVetteguy84
OldVetteguy84's Avatar
I saw mention of shimming or otherwise adjusting the latches on the firewall. Aren't they riveted in place?
Old 10-31-2020, 06:29 PM
Factoid
Factoid's Avatar
Received 5,505 Likes on 2,778 Posts
No, they are bolted in place, but this is an old thread.
Quick Reply: [C2] Hood Alignment
