FS: [MA] 2004 Z06 black - 68k mi
Cruising
[MA] 2004 Z06 black - 58k mi
2004 Z06 with just under 57,488 miles. Car has been in the family since 2008 when it had 2,500 miles on it. I am the fourth owner and have been daily driving it for the last 5 years or so. My winter car is probably on its last season due to frame rust so I am looking to move to a single, slightly more practical car year round. This car has been a true daily but parked once the first snow of the season hits. (I know the pictures say otherwise but the roads were dry and I needed the pictures) Oil changed at the end of every year before storage; this was essentially equal to when the DIC prompted. Ranger method for clutch and catch can drained every month. The mods were geared towards drive-ability and maintenance for a better daily.
18x10.5 Z06 wheels (2 OEM and 2 replicas)
Prismatic Powders "Goldtastic"
295/35 Michelin Pilot Super Sports
Powder coat and tires new as of beginning of season, ~6500 miles
Lowered about half way on stock bolts
40% metallic tint
Plasti-dip GS stripes put on this year
Shorty antenna
Front support guards
Corbeau A4 Leather w/ spacer mod
Trunk Partition
Aluminum "Grid" pedal covers
iSimple 30 pin with a BT adapter
TPS short shifter w/ anti venom mod
Halltech air intake
CCA oil catch can
SCP LMC5 and under hood skip ship delete
ECS mail order tune (stock thermostat)
Diehard AGM battery (slightly larger than stock)
Misc. items:
Two car covers
Jacking pucks
Front license plate filler
Have the stock antenna, headlights, shifter and air intake that may be included depending on the price.
Issues:
- Slight driver side rear fender damage (from a parallel parker last year)
- Driver side front fender cracked on bottom behind wheel (hit an outlier raised structure when my road was being repaved this year)
- HVAC unit has a light out
- AC compressor clutch makes noise sometimes. Goes away after driving a bit or turning AC on. HVAC works perfect regardless.
- Passenger side secondary air check valve (aka the one behind the engine) was throwing a code two years ago and probably needed to be replaced. I elected to get it tuned out; no ill affects and passes inspection.
Putting this out as sort a of a feeler but interested in selling nonetheless. I know the wheels and the light damage may scare a lot of people away.
Asking $14,000. Located in Western MA. Clean title in hand.
40% metallic tint
Shorty antenna
Trunk Partition
Halltech air intake
CCA oil catch can
Misc. items:
Two car covers
Jacking pucks
Issues:
Cruising
Cruising
I put the stock headlights back in today. Figured I'd grab a picture of the odometer since I forgot to earlier and come to find I had the wrong mileage written down....Actual mileage is just under 58,000 not 68,000. First post has been updated to reflect changes.
Received 19,302 Likes
'20-'21-'22-'23-'24
Member hasn't had any activity on the forum since December 2018. Closed the thread. If member shows back up, the thread can be reopened.
