Need new Radiator. Cooling with the cutdown models?
I need a new radiator and have been looking at RSD and dewiit. I like the cutdown and plan to use a custom 4 inch intake with my blower. Are there any cooling issues with these? My car is black and on 90 degree days it gets rather hot. RSD is going tio have a black friday so no is the time to pick one up. Any experiences?
Just figured I'd vomit some information... I'm sure Nick and others will chime in to correct me and add with their wealth of info, but I'd suggest staying full size core if you can and lowering things down enough to jam the 4" pipe in there, or going cutdown but trying NOT to run the EOC and TOC through the cutdown radiator to save on capacity for HOT days...
The Mishimoto radiator for the C6 is notched out of the box and clears a 4" intake into the throttle body. It's also the same height as stock and twice the core thickness so it will improve cooling.
FWIW............... I have a DeWitts history. First one was the full size with EOC. It worked OK for a stock engine with a PS1. When I upgraded my engine, I replaced it the shorty model and installed a separate EOC. I replaced this set up within 300 miles because it simply did not cool sufficiently. My ProCharged 6.8ltr LS2 experienced coolant temps in the 240+ range in summer heat. I am currently running their full size radiator, and, with the separate EOC, it works fine. DeWitts does make a superior product. Just need to select the correct one for the job.
No good reason to run cut down. Modify mount if you really need a pretty intake tube. You can make 1000+ with ease with either stock inlet and just take it off for races. Filter is typically restiction before the tube. Yes cooling takes a hit with smakker radiator. If it is a race car that doesnt have ac, doesnt drive when hot, etc then do whatever.
My goal is to get as much as I can out of the TI. If the temps stay under 220 in the hottest of days in traffic I’m good.
Ti wont stress the inlet. Run a full size.
Won't be near to that hp and as I said, you can run a 4" without curdown and just pop inlet off for races.
Im running a A&A kit(C5). How can I run a 4inch intake with a full size radiator? I already have the spacers in the radiator support from the kit. I dont see how that will work.
I cant belive that the A&A dongle isnt restrictive, it gets super thin over the radiator. Wish I would have thought to take off the filter, then the dongle when I was dynoing it.
You asked if the cut down hurts cooling and a few guys with experience have told you it does.
Also been said that guys have made 1000 with the dongle, and you won't be near that.
Why ask if you don't believe the answers. Try a cut down rad and let us know how that goes.
Multiple people told you the same thing. Yes it runs hotter and doesn't cool .early enough for most street cars. You are just waiting for one person to say it runs fine to justify doing what you want.
You can modify the cradle to lower the mounts. Either way filter is far more restrictive and if you want to make 1100+ need to take filter off. Just pop the whole inlet off when making 1050 isn't enough and run a screen or vstack. Enjoy the better cooling. There is no decent reason to run cut dowm radiator.
Thank you for saying I can mod the craddle. I will research that. Trust me, Id much rather run a full size than the cut down.
Just want to maximize the set up.
Ok. I'll be the exception to the rule. I have been running the cut-down radiator for about 8 years now. I have only had cooling issues once (gridlocked traffic in the Houston summer). My car is a sleeved LS2 block, making just under 1100 at the wheels with a cut-down Dewitts (no coolers in the radiator) and electric water pump with a 180* thermostat, dual spal fans running on the factory controller. I am switching to an LSX block this month so i might experience some cooling issues with the iron block but we will have to see.
I also have cutdown and got it to cool after spending $3k+ in other cooling mods. Didnt know about lowering cradle 6+ years ago or the fact the 4" tube basically does nothing, it is all in the filter. Like i said, no good reason to run cut down these days. Also limits fan selection. Yes it hurts cooling, enough to overheat depends on use, combo and location. If i lived up north, hell i would run a half size honda radiator.
I live up north in MN. It gots hot and really humid. I’m going to mod the cradle to move the radiator down even more and Toruń the full-size. What are your thoughts on the spal fans? They look nice and my stock fans are cut for dongle and look like crap now anyway so I might do it for that reason alone.
Which spal? There are good and bad ones. Cheap ones worst than stock. Have to spend $600+ for any decent ones. Prospeed dual setup is the way to go.
