I messed up touching up front splitter...
Never fails, the times I do take the Z out I end up hitting an unavoidable road debris. I tried to touch up and now I made it terrible. Please help.
I hit the few spots then used a clear coat. When I backed it out the garage it looks like **** in the light. I messed up bad.
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Front splitter is not too terrible to replace. Handful of bolts and some rivets to drill out.
Just order a replacement, there are some less expensive options on the market. ACS makes a pretty decent piece that looks OEM.
I suppose alternatively you could pull it off, take it to a body shop, and have them sand and repaint it, although I'm not sure it would be much less expensive.
Is the paint gouged or just scratched? I assumed it had a pretty big gash in it if you were using touch up paint. Maybe you should hit it with an orbital polisher first and see what you can polish out and then go from there. Not sure I would use 150 grit on it unless you plan to repaint, that is pretty aggressive.
I have OCD.. it was a small circle chip and few specs but I got carried away when applying the clear so it showed streaks in the sunlight. I just went out and took the side of a toothpick and rubbed it all off! Lol I’m gonna leave it alone now haha. Thanks for ur suggestions
Received 8,928 Likes
I don't think you want to use 150 at first. To make it look good you are going to have to use 1500 or 2000 grit paper to get out the scratches and it would take a lot of sanding if you started with 150.
Bill
Bill
mike_engr (11-24-2018)
Just drive it and have fun. By the time you fix, you'll end up hitting something else.
the car is your slave, not the other way around.
Dealerships have bumper magic paint crews that come around once per week usually. They paint whole noses of cars for 300 bucks.
if you can find their schedule, I'm sure for 200 or less, they would paint that piece for you.
have fun and don't stress. Your time is worth more than 200 and they will do a better job. Take your time and find someone who can do it well, and in the meantime, have fun
For future reference, 150 grit paper is way too abrasive. I would start with 400 or higher and then gradually move up to 1500 or 2000 grit. The sanding marks from 150 will be close to impossible to remove without good risk of going through the clear coat if it has not penetrated it already in the initial sanding with 150 grit. Always use the least abrasive paper you can.
Simple problem, simple fix , minimum heartache.
Hit it with 600 and try to level out the high spots while going light on the other areas that have no issue. No sense creating further damage to be repaired. From there you can work your way up to 1000, 1500 and 2000. Then use a good polisher to bring back the luster with some compound. A finishing polish will be the last step.Tape off the areas around where you'll be working to avoid further issues.
Buy a new one. Have it covered in xpel or similar product and enjoy the car.
or park it on blocks and shrink wrap it....
OCD is nothing. You can snap it easily (especially if you focus on some other project). Leave it alone every day and over time you learn to live with these small imperfections.
Received 1,984 Likes
I have a great and reasonable body shop. They work on lot of wrecks and enjoy a small project like this. Probably a couple $100. You need to find someone like that. Cures ocd
FWIW, it's a consumable component for anybody who drives the car with any sort of speed/aggression.
I buy them from ACS in primer and paint with a $5 rattle can in satin. Looks great and costs basically nothing to paint or repaint/touch-up.
Have you spoken to your insurance company? Since you hit something on the road it might cover at least some of the cost. I hit a curb with mine and crack it and they covered almost 100% of the cost.
Supporting Vendor
