Problems Starting
Navigator
Problems Starting
Was told that my Battery my have a bad cell. Had it check and it check out ok for a 2 year old battery. Have had to charge battery and the car would start, but now I only get a click when I try to start it. C6 corvettes do not have the trickle charge system. Could it be the starter or the starter push switch.
If it was my car, I would go through all the battery connection points and make sure there was nothing loose and no corrosion first.
The car will act like it has a bad battery when there is corrosion or a bad connection.
Also if charging it fixes the issue for a short time, you might have a parasitic drain on the battery from a control module somewhere in the car. A good dealer or repair shop can track it down for you.
Best of luck tracking down the issue.
Received 3,625 Likes
2016 C6 of Year Finalist
I love your color matching pocket square in your suit coat pocket!
As for the battery...if it sits for a while it should be on a battery tender/maintainer. You can go big bucks and buy the GM issue, less bucks for the Battery Tender JR, or the cheap (but long lasting) Schumacher from Walmart. I have a couple that I bought for around $20.
Charge the battery, check for parasitic draw, and put it on the tender when not in use,
My daughters car was acting the same way had the battery checked and it tested ok. Would jump the car and would be ok for a few days then go dead again. Turned out to be the positive connection was loose. Tightened up and all is well as posted before check all of your connection points.
Our first Corvette was a 2005 Base Coupe with the A4 transmission. Anytime it sat in the garage for more than 3-5 days it wouldn’t start without being jump started. We bought a new battery and all was well. This seems to be common problem in early C6’s. FYI, it seems 24 month batteries aren’t always as good as they used to be. If your C6 isn’t daily driven, a new battery just might be in order. Best of luck.
StingBeeZ06 (11-21-2018)
Whoever designed the terminals for for the car should be fired at GM.
This may sound crazy but do you have your cell phone in close proximity to you key fob? If my IPhone is within 2 feet of my key for, all I get is a click. Move the phone, car starts right up. Just a thought.
