Is an Awesome Exhaust possible for $500???
Got to follow my wife driving my Grand Sport today, and although the looks were there, the exhaust didn't sound anything like I thought I'd heard from inside! (Wife was pampering it ) Got lots of things I'd like to do with car, but at the moment ... was wondering if any innovative ideas are there that could get some awesome sound for $500 or so bucks? Thinking an X Pipe alone won't get there
That would lose my NPP valve control though, right? ... Would kinda like to keep the NPP option ....
A few questions before you go crazy.
1. What mode was the exhaust set at? Tour, Sport, Track?
2. Auto or Manual? and was she at least above 1700 rpm? In Track mode the NPP valves won't open until 1700rpm. In Tour and Sport they don't open til even higher rpm levels.
If you want the valves to remain open all the time then you can pull the fuse. I would definitely not hack up the nice NPP exhaust you have on the GS already for a muffler delete. You will lose the ability to control the exhaust volume with the valves and imo it just cheapens the car.
There is nothing else you can do for $500. If you want a real upgrade then you would have to look at the NPP compatible systems from companies like Borla, Corsa or BBE but you are talking $1800+ for a nice setup. I would do another test and have her wind out a gear so you can really hear it. When I set my NPP exhaust to Track mode in my GS Vert and I have the top down, good lord it sounds awesome and loud. At about 4500rpm and up it generates a nice loud and raspy note that should be easily heard.
Falcon, .. I thought I had the manual exhaust settings setup in Track Mode? ... Haven't been to that page in settings but maybe once, but I thought I had it set to perform as if the car was in Track mode. I do know that i had set the drive mode to "Economy" for her, because I wanted the most compliant ride while she had it. Just happens that I ran into her on the way home and got behind the car to listen to the exhaust!
By the way, ECO/Tour have the same suspension setting as far as the magnetic ride goes. Sport and Track will firm up the shocks.
That probably does explain a lot. I do think I have it set to Track Mode in Sound Management, but I'm pretty sure she never got above 2,000 rpms while I was listening. An addition of a Borla X-Pipe might get me closer to where I want to be after all then? By the way, ... I saw a Youtube video where a new Z06 had installed an "Armytrix X-Pipe and Axle-back Valvetronic" exhaust, ...and ... even without headers, ... This had to be the most wicked C7 Corvette exhaust I've ever heard! I was listening though my earbuds plugged into my desktop, and .. OMG!!!
An X-pipe will increase volume a bit since we have two sets of cats and you can delete one set with the X-pipe. If you add Long Tube headers it will be even louder but I would start by making sure your NPP exhaust settings are set correctly before dropping a bunch of money.
If you want to keep the NPP functionality, then you will “generally” need more than $500 for any compatible cat-back system. You could go with headers, but tuning is “generally” required and raises concerns about the warranty. Your best bet, based on information that you’ve provided, is to start with a cat-delete X-pipe, i.e., Borla, Corsa, etc., and go from there... It’s an inexpensive and easy install that will increase volume without throwing codes, and will not affect the NPP.
Remove the fuse first. If that's enough for you and you want to keep NPP, then Mild2WIld it is.
Otherwise, if you want to maintain NPP with an aftermarket exhaust...$2k.
That said, I have long tube headers and x-pipe (catless) with the OEM NPP mufflers on my Z. The car is still way to quiet (and I have M2W with the fuse "off" most of the time).
I just ordered an aFe axleback. Hoping that will get me where I want.
Just an FYI, the Z06 will sound different. The camshaft profile of the LT4 delivers greater valve lift and duration than the LT1. Also, LT4’s compression ratio is 10.0:1 compared to 11.5:1 for the LT1. Moreover, the Z06 measures 5+ decibels louder than the LT1 NPP. While this isn’t a dramatic difference, it is noticeable, particularly when listening to them side-by-side.
John Micheal Henry (11-21-2018)
I've seen Armytrix exhausts on Bimmers. They're nice. But I like the design of the aFe better. That said, I haven't heard any sound clips from this exhaust except the short crappy video aFe has themselves. Hoping it sounds good, but we'll see!
The Armytrix sounds, to me, less impressive here:
Keep your NPP as is.
Upstream of the cats, have a bypass exhaust valve installed. Similar to a "mildtowild" remote controlled. This will open up your exhaust just past the collectors. It'll be plenty LOUD.
It'll "pop" too on decel.
You might be able to "tune" the EPA lean "pop" out, with help from a person who knows "How to tune."
Then, you can close it and return home after midnight, all stealth like.
Just pull the fuse on the NPP. It locks the valves open and makes it sound like it is supposed to in the first place without the "BOOM" you get when the valves open at low RPM. The best part is....its free. (Trust me...you won't miss the selectable exhaust note)
