C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
more ugrade ideas?
Old 11-25-2018, 10:25 AM
hmmmm16417
hmmmm16417's Avatar
Default more ugrade ideas?
So, after sitting in my garage attic for a year, I finally installed the headers last night while care was in my garage on jack stands. I'm probably going to do the tune through Diablow Lew but assuming will have to wait until spring when I can actually drive the car and log the info.
I'm looking for other ideas for anything that I can/should do this winter before a tune that may help. Any ideas for upgrades that are worth the money vs. gain?
Not looking to spend thousands..... but maybe I'm already about as far as i can go for now .
current mods:
OBX/Maximizer long tube headers w/ catted x-pipe
Airaid CAI
Corsa sport axel back
Diablo sport trinity tuner
I will more than likely be initiating a tune via Diablo Lew this spring to bring it all together.
anyone have a similar set up that can give me an idea on HP gained from stock?
what would next step(s) be?
Old 11-25-2018, 06:22 PM
irok
irok's Avatar
a ported Fast 102 would be a good next step.
Old 11-26-2018, 06:34 PM
hmmmm16417
hmmmm16417's Avatar
I've been looking at those actually
Old 12-03-2018, 10:14 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
I would deff not go to a larger T Body We were trained at EFILIVE to only use a larger T Body IF
1 you increase your cubc inches from stock
2 Major mods --Huge cam better flowing heads\\
3 You typically run your car above 5500 RPM's ALL the time
It's like putting too big a carb on an old sch engine--You will lose bottom end HP/TQ as well as mid range but add only minimal HP at WOT
I'm not sure you can properly tune LT headers with the Diablo tuner
THE best mod peeiod you can make on any automatic car is to add a stall converter
This wakes up even the laziest of cars I would recc a 3000 Stall for your car
Chuck CoW (12-17-2018)
Old 12-04-2018, 06:09 PM
hmmmm16417
hmmmm16417's Avatar
Haven't even thought about a stall converter yet..... may look into that .
I saw throughout the forum that using the trinity tuner I could send logs and have it custom tuned by Diablew ? that isn't very good?
Old 12-05-2018, 11:11 PM
tblu92
tblu92's Avatar
Yes it is good as a lat resort---However you will end up doing many emails back and forth and trying to explain whats going on in your car----Best is to have a local tuner work on your tune and they will actually DRIVE your car and realize all it's tuning deficienies----Much easy to tune an engine when you can drive it-----A mail order tune is just "their best guess:"of what needs to be changed--
Old 12-06-2018, 09:41 AM
myredhead1
myredhead1's Avatar
If car is an LS2, I would venture to say that a ported Fast102 is the best bang for the buck improvement, pre tune. If not wanting to spend quite that much, get your LS2 stock intake manifold radically ported.
Old 12-06-2018, 07:49 PM
hmmmm16417
hmmmm16417's Avatar
I'll have to look around. Not sure there is a reputable tuner in my area. I know of a couple that do motorcycles, but not sure about cars.
Old 12-06-2018, 07:51 PM
hmmmm16417
hmmmm16417's Avatar
Yes, it's an LS2. I've been looking at the fast 102, but still debating. it's starting to seem like one mod leads to another essential mod. hahahaha
Old 12-06-2018, 08:53 PM
0HorsePowerAddicts
Former Vendor
HorsePowerAddicts's Avatar
As already said, A fast intake and ported TB will be a great addition for HP and throttle response. Then your looking at installing a cam next if you wanted to stay NA and go farther than bolt ons.
hmmmm16417 (12-06-2018)
Old 12-08-2018, 03:04 AM
Scott Tenold
Scott Tenold's Avatar
MSD plug wires might give you a bump. Also a lot of people talk about e85 conversion. Just thoughts
Old 12-14-2018, 07:51 PM
c6 monkey
c6 monkey's Avatar
You'd be amazed what a difference a throttle response controller will make. Chuck Cow can program your cars computer with similar results. Reallt cheap mod, huge difference.
Old 12-15-2018, 02:07 AM
Scott Tenold
I have seen the adds for people selling them but didn’t really understand the concept. Basically it speeds up the the time of when you hit the accelerator peddle to how fast the computer tells the car to go. So faster reaction time? What did you get out of using it? Do you have a light fly wheel? Sounds like the would go together really well. Also sounds like it would work well for drag racing for reaction times.
Old 12-15-2018, 03:08 PM
c6 monkey
c6 monkey's Avatar
It wakes the car up. Makes it snappier, way better. Look at Vittesse, they make it adjustable. You can find them used here sometimes for $125 or so. No brainer.
Old 12-17-2018, 01:01 PM
demon340
demon340's Avatar
I ported my stock LS2 intake, also added a vararam and it was a noticeable gain especially over 3,500rpm on my stock engine. I would guess 15 to 20hp with most of it coming from the intake. I really didn't do much to the plenum just the runners.
Old 12-17-2018, 04:35 PM
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thank you very much!
YES, the CoW BOOSTER! is amazing and can be set up any way you like.
Throttle bodies and fast manifolds are virtually worthless without displacement, compression, or big camshaft mods. The perceived improvement comes
comes from a slightly larger throttle body but you can get much more bang for your buck with a $199. CoW BOOSTER!
Thanks again!
Chuck CoW
Old 12-18-2018, 12:47 PM
irok
irok's Avatar
With a ported Fast 102 and OBX catted LTH's my car picked up between 55 and 65RWHP NA depending on DA and dyno car was on with no increase in compression,displacement or large camshaft
To more ugrade ideas?
Old 12-21-2018, 12:58 AM
tblu92
tblu92's Avatar
Sorry I can't beleive this maybe on a Silverado that is not well tuned however a Corvette is already well tuned from the factory and the mods you say you made a 102 Fast intake and LT headers do not equate to 65 RWHP
The Fats intake also only makes best power gians at WOT like above 5500 RPM 's and maybe even being generous you would see on a STOCK INTERNAL engine at best 15 RWHP --Then LT headers only after being tuned may add another 25 -30 RWHP So combined this is only about 40 45 RWHP --even after a tune----As when adding the 102 and LT;s your HP and TQ may be even LESS than before until you have it tuned---These mods are worhtless without re tuning and even then no where near 65 RWHP !!
Old 12-21-2018, 10:37 AM
demon340
demon340's Avatar
EASY 60rwhp with a good tune and CAI in place of the crummy ls2 stocker!! And your completely wrong about the fast only making best power over 5,500 rpm. Where did you get your info ???
Old 12-21-2018, 10:41 AM
myredhead1
myredhead1's Avatar
A ported fast 102 may be the absolute best mod for an LS2. The difference is throughout the entire power band, not just up top. A good port job can add 7-10 rwhp over a non ported one.
Quick Reply: more ugrade ideas?
