AFR 180 or 195
AFR 180 or 195
Hey guys I have a 383 stroker with 041 heads that bench flowed 244. Engine has 440 hp and 480 tq, looking to upgrade to some AFR heads, my cam is 1500-5500 rpm range cam Howards roller (512 total lift) . What kind of gains do you thing I my see with these heads?
180's flow 260 at .500
195's flow 274 at .500
Thanks
Thanks
Received 1,877 Likes
2017 C2 of Year Finalist
Need to look at ALL the flow numbers to at least get an idea. The valve is only at .500 for an instant...but it's at 200,300, 400 twice and all points in between.
Those 041's are doing pretty darn well..must be some good work on them.
How high do you actually rev it? Gears? Trans? Induction? What are duration numbers on cam?
JIM
JIM
NewbVetteGuy (12-04-2018)
I think you need to do some soul searching to figure out what you are really trying to accomplish. The cam you have is tiny, and so a head swap really isn't going to amp up the power much...I'd guess 20 horsepower, which you probably will not even feel. For the money spent on heads...that's not much gain.
Depending on your ultimate goal, and the existing combination...gears, stall,...a cam swap might be a cheaper, and far more productive course of action. Once the cam is in, you may then realize the engine can use more head flow. and a head swap will really be worth the expense.
I went through this issue in 2014 with my L-82 355 during the rebuild with my expert builder (undergraduate engineering major plus 16 years as a GM field Tech teaching GM mechanics around the country.).He really knows his stuff and builds real high performance GM motors and tests them......I go by what HE SAYS and everyone else is commentary/opinion, for the most part.
My engine is a 355 with AFR 180's, compression 10.2:1 with howards roller cam (.525/,525 lift, duration 219/225, LSA 110 operating range-1,500-5,600 RPM) and my research indicated that the AFR 180 would be best and supported by my builder for my motor. Bigger heads are NOT going to offer more flow without some penalty depending on the motor. Peak flow is not the whole story since flow at every cam lift point matters. Since my cam operates in the range sub 6,000 RPM and I was looking to maximize mid range torque, the AFR 180's had the best combo of peak flow, mid lift flow and port velocity which effects throttle response. The AFR 195 would provide slightly better peak power on my motor with my cam BUT would hurt low to mid range TQ. I would not slap on bigger heads and think there is no downside, without the right combo of parts...there is!
For your 383 with a cam that has the same operating range as mine, I think you would want to go AFR 180 but being a 383 which is marginally bigger than a 355, AFR 195's would be better suited for the right cam for that motor, as a very broad comment, if you intend to rev beyond 6,000 RPM.
Check this link out:
http://www.wallaceracing.com/flow-rpm.php
Using that calculator, a 383 running at 5500 rpm requires a head capable of flowing 202 CFM. That's assuming 100% volumetric efficiency.
MajD
MajD
RPM's is 5400/5500 and I have 355 gears.
not going to be racing just weekend cruiser. Did part of power tour this year but plan to do complete course next year.
cam is 286 286 230 230 108 LSA 106 ICL
Thanks for responding.
Dr. Detroit
Received 3,892 Likes
This is if you do not plan to upgrade later......in that case, the 195 is a better choice in the long run.
The 180 would have brutal torque with that cam....it would feel like it has power everywhere......less shifting.
Jebby
it but I’d be more inclined to use them on a 350.
Jim
This is a difficult decision......but I think here I would do the 180 and get the small chamber to get the compression as high as possible......the small heads and the fast burn chamber with high compression would be a wonderful street brawler that would light throttle cruise like no other.......
Jebby
Jebby
This description is my motor with decent compression, AFR 180's, and the howards Roller cam described above...AND it is a 355, not a 383!!!!!!! Those AFR 180's with the right combo of parts on the right engine are magical..........
Received 2,127 Likes
Just cruising, going to the store, going to car shows, traffic-light to traffic-light burst, I wouldn't worry about 15 cube difference. Its not Super Stock racing.
The 180s will be fine.
Just like carb CFMs, bigger is not always better.
edusmc1 (12-04-2018)
I have both the 180 Dart heads and 195 AFR heads. Which do I like...both. They both did and do the job on my 383, but I happen to like the 195s that are on it now with the higher CR and much bigger cam. I breaths like crazy mid range and up top of course. I should be going to the track in the near future and see how it runs compared to the old 383 motor. 12.95 ET with the old motor running CFI.
jackson (01-15-2019)
May not be the correct thread but close enough. I currently have a 355 with the Howards (111145-10) retro roller cam, 110 LSA .510 in, 525 ex with 1.5 roller rockers. the operating range is 1500-5600 which I am very happy with. Moving on, heads are Dart 180 SHP 64cc. Intake is a Edelbrock Airgap performer 1500-6500 RPM Range. Have installed a Holley Terminator some time ago and it is great. I recently installed a dual sync distributor for the addition of running CNP with LS7 coils. Everything works great. Have a TKO 5 speed with a BB 308 rear. The combination is perfect for my cruiser and I keep up with C7's all day long without any issues. About 2K RPM at 70 MPH. So my question is; I am wanting to go to MPFI using the Holley Terminator (which is a Holley HP). My problem is I don't understand the relationship between a dry runner intake (MPFI) and a wet intake (TBI). The CFM or RPM range has me confused. I only see MPFI manifolds starting at 2200 RPM. Most start at 3000 RPM and go up. I want the intake manifold to compliment my current cam and heads while using the benefit of MPFI. My dilemma is will a broader RPM intake cause my combination to go out of wack? Will as an example an intake manifold (MPFI) with a power band of 3000-7000 be okay without having to change the cam or cylinder heads? Would i just be loosing a little low end torque? I don't race the car but do some spirited driving when with the big boys. I hope I have provided enough information to get a good answer. I have built engines in the past being careful to match parts to get the best performance from the engine, I don't want to screw up my current setup by having an intake manifold that has runners to large for what I want. Thanks for any help and I do apologize if this is not the right place. Not trying to hyjack the tread, just looking for a little advice.
195s for a 383 and if you currently have 1.5 ratio rockers, buy a set of 1.6 ratio rockers for the intake side.
You want to size heads based upon the min CSA, not just the advertized port volume. You'll find that AFRs have a slightly smaller min CSA for every volume vs. most other top-shelf heads (Because their port designs are so dang efficient.).
The correct formula for determining how big of cylinder head you need (This formula is focused on flowing the air at max port speed at your RPM peak for your cubic inches):
MIN CSA = (bore x bore x stroke x RPM x .00353) / 613.8 (.55 MACH x 1116 fps)
The AFR 195 COMP head has a min CSA of 2.1 or 2.15", which is EXACTLY what the engine builder calc says you should have for a 383 with a 6,000 RPM peak.
Adam
- SBC 383 Version: 6,000 RPM peak
- Min CSA= (4.03" x 4.03" x 3.75" x 6,000 RPM x 0.00353) / 613.8
- 1290/613.8
- 2.1" Min CSA
Adam
The following 2 users liked this post by NewbVetteGuy:
76strokervette (01-15-2019),
Dr. Detroit
Do you know why a dual plane works better down low? Because the 180 degree left/right pulses "signal" the booster better than an open plenum. That's it.
EFI needs no signal...the fuel is introduced.
You will lose no power anywhere given the EFI is tuned correctly.
Why not go to a large runner intake then? Because you want to help speed up and keep sped up the airflow right down through the runner into the cylinder.
Jebby
condor7 (01-15-2019)
I do not think you would regret using the AFR 195s.
I have the AFR 180s on a 350 with a 108 LSA cam 270/270 , 219/219 with .549 lift. It’s a beast on that engine, much better than the dart SHPs I had previously.
with the cam you have, I would get some 1.6 ratio rockers, assuming adequate valve clearance, use the 195s and you have a reAl screamer assuming nothing is choking the system prior to the heads, ie intake manifold, carb, air cleaner etc.
Make sure the exhaust is un obstructed as possible, it will not like any back pressure.
im using side pipes to insure little to no back pressure. My 180s rev freely up to valve float at 6400 ish rpm.
