GEN Light on
GEN Light on
Hello
Just bring back my 1977 vette from the mechanic for breack check and now the GEN light ramain on after the engine is started.
I don't think is related to the job made on the break.
Any suggestion ?
Thanks
Any suggestion ?
Thanks
IvanoMan (12-01-2018)
1) What does your voltmeter read? If it is straight up, pointing at 13, and remains so as the engine continues to run, your alternator is supplying current to the system.
2) Look at your alternator. There should be an 18/20 gauge brown (or possibly white) wire attached to it. This wire goes back to the plug in back of your center gauge cluster, and then to the GEN light. It performs 2 functions - a) it excites the alternator when starting, and b) Warns you when the oltage at the alternator is less than the voltage in the battery. If it is disconnected, your GEN light will come on.
IvanoMan (12-02-2018)
Several things to look at:
This^^^^^^^
I doubt that the alternator just failed at the mechanic BUT it could. More likely the mechanic touched a wire ^^^^^^ causing the Gen light to illuminate
This problem can be a real hassle. I've had it many times in the past, chasing different things. I eventually sent it in to a mechanic(which takes a lot for me), he put on a self exciting alternator, never had the problem again.
Thanks for the suggestions ,
Just cheked and the cable are connected.
Double checked with hand unplug and plug again.
The red light is still there.
The volts gauge indicate 13V
mmmm.
mmmm.
Do you have a link to the self exciting alternator?
What does it mean self exciting?
He didnt fix it, he bypassed it.
I suspect that it is associated with the job on the brakes; not definitely, from my experience of messing with things. If your alternator is putting out 13 VDC then the is charging (assuming your battery terminal voltage when off is about 12 VDC). but it really should be maintaining closer to 14 VDC
What was he doing to the brakes? Perhaps we can narrow down the search area.
I suspect that it is associated with the job on the brakes; not definitely, from my experience of messing with things. If your alternator is putting out 13 VDC then it is charging (assuming your battery terminal voltage when off is about 12 VDC).
The alternator should put out at least 14.2 volts not 13. Check it running across the battery. You can bypass the regulator to make it energize.
No less than 13.8 volts generally under load.
A fully charged battery under no load could be as low as 13.2-13.4...........
Much depends on the alternator type, revs, load, etc........
There really is no set number...except it should be more than 13 volts generally....
here's a link. Much better price than the one I just got for my 02 vette, it was $380 on amazon. C5 needs to have the internal circuitry to communicate with the PCM.
IvanoMan (12-05-2018)
Please check the voltage with the engine running at an idle. The standard is 1 volt over battery voltage. A fully charged battery is 12.6 volts, so your minimum voltage should be 13.6 volts.
Voltage is just part of the electrical output, the other measurement is amperage. The alternator could be putting out voltage but not sufficient amperage. If you do as previously suggested and have the unit tested at Autozone they will tell you if it's performing properly. After checking all of the wire connections, and broken wires, testing the alternator would be next on the list
IvanoMan (12-06-2018)
