Borla X-pipe
Borla X-pipe
Were the Borla X-pipes always over $400? And who has them at the best price? I know Borla stopped making them as well. Thanks
I think i got mine for like 330 shipped last spring, well 2 springs ago, in 2017.
They're becoming popular so it makes sense the price is going up.
Received 1,325 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Borla/Corsa Z06 x-pipe performance comparison
https://www.corvetteforum.com/forums...omparison.html
HorsePowerObsessed (12-10-2018)
The Borla is lighter and makes more power. I think the consensus is the Corsa sounds better though.
There’s a great video (search “x pipe comparison Z06” on YouTube) where a shop ran a set of dyno test with both pipes, as well as a titanium x-pipe and then the titanium with an Akrapovic. The Borla made 22/13 over stock.
LHT Performance made a one off custom X out of titanium for the heck of it for their 2017 M7 Z06. It was kind of a cross between the Corsa X (sound wise) & Borla X (where the pipes actually cross/X together) but of course it was very light weight being built out of titanium. I wish someone would produce more light weight components like this.
- Stock X = 25.10 lbs.
- Borla X = 18.3 lbs.
- Corsa X = 22.0 lbs.
- Titanium X = 7.13 lbs. (listed as 8.2 lbs. in 2nd video)
- Stock car: 578.3 hp/602.4 lb-ft.
- Borla X-pipe: 600.1 hp/615.6 lb-ft.
- Corsa X-pipe: 595.2 hp/616.5 lb-ft.
- Titanium X-pipe: 605.9 hp/611.3 lb-ft.
- Titanium X & Akrapovic exhaust: 620.9 hp/609.3 lb.-ft.
Dyno Runs:
I've posted this several times, most recently in the C7 General section but I think this is what you're referring to.
https://youtu.be/1XdW5q1r9Mk
Dyno Runs:
https://youtu.be/-8l27NfE2-k
Dyno Runs:
Bottom line is they are all within 10 hp, tq is almost identical and the weight is also very close, so really it comes down to sound preference and cost. When you are in the 600hp range 10hp one way or the other is not going to make a difference on the street.
it should sound like what the ls engines sound like imo. And even if you do long tubes and a borla it doesn't really get there but it's close.
I like borla because it got me closer to what my c6 sounded like with long tubes and full exhaust. I didnt want my car to sound exotic.
because it's not an exotic.
corsa makes our cars sound exotic, like amg or Aston Martin like. Our cars aren't that type..
