FS; Dewalt 30 gallon air compressor
Used for about 6 month in my garage, never out in the field so it's in very good condition.
Model number DXCMLA1983054
500$ obo
Located in Irvine
Text me anytime 714 2o6 1749 or PM me in this forum.
Also willing to trade for c6z06 front end parts. I need front bumper,hood,headlights,windshield
Here is a description from Home Depot/Lowe's website.
https://m.lowes.com/pd/DEWALT-30-Gallon-Portable-Electric-Vertical-Air-Compressor/1000013900?cm_mmc=SCE_PLA_ONLY-_-ToolsAndHardware-_-CompressorsDiyAndStationary-_-1000013900EWALT&CAWELAID=&kpid=1000013 900&CAGPSPN=pla&k_clickID=go_625664149_3 4614603070_111134380030_pla-436698074635_m_9031524&gclid=EAIaIQobChM I8rf0uf2B3wIVDY1pCh1c4gPgEAQYASABEgJt3fD _BwE
DEWALT 30 Gallon air compressor features a cast iron, twin cylinder, oil lubricated pump. Compressor runs on a heavy duty induction motor for maximum performance and efficiency. Max PSI is 155 for optimum tool performance. Compressor is made in the USA.
DEWALT 30-gal, 155-PSI vertical portable electric air compressor for various projects in the workshop and jobsite
It features a 120-volt, 1.9-HP heavy-duty induction motor with belt drive oil lube design for long life and quiet performance
High flow regulator provides more air to the tool when need for tough jobs, like loosening a rusted nut
Quick-set feature on the regulator enables you to set the gauge to the precise pressure needed to prevent damage to the tool
Vertical tank design is ideal for compact storage
10-in pneumatic wheels mean easy portability around the workshop or jobsite
2-year limited warranty gives you peace of mind
Controls are at a height that makes it easy to adjust gauges without needing to bend over
Plugs into a 120-volt home outlet but can be converted to 230/240-volt if necessary
500$ obo
Located in Irvine
[img]blob:https://www.corvetteforum.com/5209d0b6-7be1-4d16-8d7b-db092b61053a[/img]
[img]blob:https://www.corvetteforum.com/f1979eaf-4795-48fb-9cec-80525da15a27[/img]
