FS: 1962 Rochester Fuel Injection
Recent rebuild. Price $7250 plus shipping or free pick-up Denver Colorado. Xmas 2018 Special Price reduce to $6,950.00. Make an offer if you can use it.
a) Viton seals
b) Carbon seals used in the high pressure fuel pump
c) New OEM injectors #7017323 Gr no 3.332
d) New OEM Distributor #1111070 date code 3L6 (Nov 6, 1963)
e) Fuel shut-off upgrade. Will include original fuel line
f) Solenoid for crank signal valve upgrade. Will include original vacuum line
g) New choke that works
h) New OEM high pressure fuel pump cable and housing
i) New AC Delco fuel filter
J) New primary and secondary spring and bracket
k) Coil bracket included. Not installed. Used for 1962 left side coil install
l) Petronic ignition upgrade with Flame Thrower II Coil. Original points included
m) Insulated fuel line and manifold
n) Model #7017360. February 1962 Tag Serial #3054
On car and encourage to see it run before you buy. Will not be disappointed. Dialed in and correct. Please note the Air cleaner is not period correct.Attached Images
Not the correct Air Cleaner
Fuel Meter
a) Viton seals
Fuel Meter
a) Viton seals
Fuel Meter
a) Viton seals
Fuel Meter
