C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Aggressive startup
Old 12-05-2018, 11:58 AM
Fte390
Fte390's Avatar
Default Aggressive startup
Has anyone been concerned with the start up in cold weather?? Seems to me it’s kinda hard on the engine
Old 12-05-2018, 01:50 PM
RedZ4me
RedZ4me's Avatar
really?? it's an engine and you have warranty
Old 12-05-2018, 02:11 PM
Fte390
Fte390's Avatar
Not an answer. Warranty? Buring oil after a few thousand miles?? Don’t think so. 12th vette
Old 12-05-2018, 02:20 PM
Fte390
Fte390's Avatar
Plus most wear is at startup. No preoiler
Old 12-05-2018, 02:51 PM
BearZ06
BearZ06's Avatar
Received 1,333 Likes on 774 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
No concerns here, the Beast is awakening! Just let warm up before pushing it.
Old 12-05-2018, 02:56 PM
RedZ4me
RedZ4me's Avatar
So now it's burning oil? You didn't state that in your post. LOL A few thousand miles? - yes, you'll have warranty.
Old 12-05-2018, 03:29 PM
DebRedZR1
Moderator
Support Corvetteforum!
DebRedZR1's Avatar
Received 3,622 Likes on 1,741 Posts
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
I am confused too. I start mine in the Michigan cold all the time. Harlan usually posts driving his in the snow every year here .........................The cold isnt going to cause oil to burn........
2019 ZR1 (12-05-2018)
Old 12-05-2018, 03:32 PM
dmaxx3500
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
I start and drive my cars/trucks all winter long,why is a zr1 any different?
Old 12-05-2018, 03:34 PM
propete
propete's Avatar
I understand your point, and have often thought the same thing but if you really think about it, all cars, even the old reliable family car have been going through this same procedure on cold start up and it doesn't seem to be an issue with the manufacturers. I suppose there is no way to warm the engine up prior to startup without it being garaged in a warm environment , like Florida where I live. Point well taken though !
Old 12-05-2018, 04:00 PM
RedZ4me
RedZ4me's Avatar
If anyone has been to a plant, car/truck or engine plant, you can't harm it more than they do after assembly, and with near zero miles - trust me.
Old 12-05-2018, 05:20 PM
Zjoe6
Moderator
Zjoe6's Avatar
Received 3,937 Likes on 2,424 Posts
Old 12-05-2018, 05:47 PM
2019 ZR1
2019 ZR1's Avatar
I won't have mine until February but I'm worried about the tire pressure when it's cold. My 16 Z06 showed 28 in each tire when it is cold and I never moved it because I didn't want to ruin the wheels.
Old 12-05-2018, 06:33 PM
Zjoe6
Moderator
Zjoe6's Avatar
Old 12-06-2018, 09:29 AM
DebRedZR1
Moderator
DebRedZR1's Avatar
Events Coordinator
Good thinking ;>
Old 12-06-2018, 11:35 AM
Mr. Gizmo
Mr. Gizmo's Avatar
buy a good quality electric blanket and wrap the motor with it for 24 hours before you start it in weather below 50 degrees
Old 12-06-2018, 12:16 PM
village idiot
village idiot's Avatar
Received 1,913 Likes on 1,053 Posts
Do you think GM (and every other manufacturer) programs their cars to idle high until they're warm because the cars didn't burn enough fuel or something? It's obviously done intentionally and after a lot of testing. Testing > "Seems to me it’s kinda hard on the engine"
Old 12-06-2018, 01:20 PM
2019 ZR1
2019 ZR1's Avatar
Hey that's a good idea man. Let me know what blanket you use. It would be nice if we could get a sticky for this. I really think you got something here..
DebRedZR1 (12-07-2018)
To Aggressive startup
Old 12-07-2018, 04:57 AM
Warp Factor
Warp Factor's Avatar
Received 1,817 Likes on 1,085 Posts
I've had thoughts too that the aggressive "VROOM" on startup may not be the best thing for the engine. I suppose it's a marketing decision, to make the car sound bad-asser, since most other GM vehicles don't seem to do it.
If I end up scaring some little old lady, or someone gives me a hard time about it, I guess I'll just explain that the computer did it, not me, and that I didn't touch the throttle.
Old 12-10-2018, 03:48 PM
propete
propete's Avatar
I don't think you are going to ruin the wheels at that pressure . The manufacturer even says you can travel 50 miles on a run flat tire that is flat so I wouldn't worry at 28psi, however I admire your concern for the well being of your car.
Old 12-10-2018, 08:40 PM
village idiot
lol they’re fine at 28.
Quick Reply: Aggressive startup
