Hoods
Hoods
Does any one know if the z06 hood is the same as the hood on a z51?
There is a aftermarket hood side vent
addation to mod a z06 hood and the maker does not know if it will fit on a z51...
The Z06 has a different hood. It’s higher and the vents are wider, however, I believe that the width and length are the same so it should fit...
A factory Z06 hood will absolutely fit on a non-Z06 C7, so in theory the aftermarket hood should also fit on a non-Z06 C7 unless they altered the design to a point where there is an issue. I'm surprised that the manufacturer of the aftermarket hood wouldn't for certain since, after all, they should be subject matter experts on hoods and they are potentially losing out on sales that could be marketed towards non-Z06 C7 owners.
Looks like your just asking about side vents, not the entire hood. Whether the vent fits or not depends on size and placement. In all likelihood, they’ll fit or be close enough that they require minimal massaging. Without specifics however, there are no guarantees.
but if the center is taller on a z06 then they most like7will not work as curvature is diffrent ... i almost would like to get a white z06 hood any way !
wander how much one would be ...?
Z hoods pop up in the For Sale section from time to time. Lowest I recall is $1500 to >$2000. Depends on color and if it has the exposed carbon fiber
Moderator
The side vent kit will not fit on a non-Z06 hood. They are clearly made to match the curvature of the center section rise which is taller on the Z06.
Received 1,762 Likes
I agree plus anyone looking at these for a z06 I think it was some what a PITA cause you had to cut a piece out from under your hood to get these to line up & bolted into place.. Robert
Not sure I see why you would ever want those?
car has vents and do dads all over it already.
This is like once it is installed 2 weeks later you walk outside and say to yourself "wtf was I thinking" type mods...
