Free Part: EN-51267 Oil Pump Housing Aligner for Camshaft Install
NOTE: This How-To guide is neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to this guide is solely placed upon the end user. (This means you!)
In FYREANT's guide on installing a new camshaft, he stresses the usage of an oil pump alignment tool from GM to keep your oil pressure from falling when you put the motor back together. Instead of spending the $130 to buy the tool, I created one in CAD and matched its dimensions to a real one, thanks again to FYREANT for providing the dimensions. I decided to give a download to the 3D model I made so that everyone here can print their own tool. Below you can find the link for download as well as FYREANT's guide to installing a cam in your C7. Here’s what the tools look like in action.
There are two downloads I have provided, one is the part with exact dimensions as measured, this is to be used on SLA, Resin 3D printers since they don't have to deal with thermal expansion. The second download is for regular 3D printers printing with PLA plastic and has 1mm added to all dimensions to account for the thermal shrinking of the plastic as it cools.
If you have a 3D printer, just import the .stl into your slicer, copy the settings pictured below and print away! If not, you can order the part from a 3D printing service like 3DHubs or materialise as well as myself. If you'd like me to print your part, send me a PM and I'll get your order in, I'll print your tool for $5 and mail it to you. For those other printing services, use the same settings pictured below.
After you get your tool printed please make sure to compare its dimensions to the picture below to make sure your tool is in spec. .5mm tolerance is acceptable. Then head over to Lowes, Home Depot or the link below to buy 4 M8 x 1.25 16MM bolts. I bought stainless steel but zinc plated works as well.
That’s it! All in, it cost me less than $10 to make my tools and put them to use. If you have any questions, please feel free to ask them below!
Links:
FYREANT ‘s guide to installing a camshaft for the LT1: https://www.corvetteforum.com/forums...all-guide.html
M8 x 1.25 16MM bolts: http://a.co/d/7BjkIme
Downloads:
3D model for SLA/Resin printers (uncorrected): http://dev.chriswhite.tech/VetteDev/...corrected).stl
3d model for regular 3D printers using PLA (corrected): http://dev.chriswhite.tech/VetteDev/...Corrected).stl
Print Settings (Only for printing with PLA):
Tool dimensions:
*Please measure your printed tool to make sure it's within specifications pictured here before using.*
*I am not responsible for any damage caused by using this tool. *
Links:
Downloads:
Tool dimensions:
Look out for the Methanol Gauge I've build for the C7 Alky Control kit coming out February 2019!
Monitor your meth levels from your phone in real time!
Matthewstorm (12-16-2018)
I'm Batman..
Pro Mechanic
Would it be possible to align the pump using the same method as an LS motor? Like this:
https://www.youtube.com/watch?v=DzUy1RdOx50
Cruise-In IV Veteran
So how do you align a NEW oil pump? I literally have no idea. And I am concerned b/c I don't see any way to align it? Other than just bolting it up?
LS oil pump must have much more clearance around the inner and outer gears in the housing.
The smallest of feeler gauges won't fit anywhere around the outer gear.
What is your thinnest gauge? Mine is .0015. I don’t recall what I used. If you can’t get even that size inserted I would think that a jig won’t help either. It’s probably ok just to bolt it on. You might wanna check with Melling.
Good luck!
BTW, was that a stock bottom end LT4 that you lost your main bearing on? When I tore down my LT1 for my rebuild I found some scoring on one of my mains as well. Crank was ok. It did last over 30k miles without a problem. Maybe dirty builds on some of our factory engines?
Good luck!
Good luck!
Good luck!
I really don't know what you do seeing that this is a fresh build. FWIW this is from the GM repair manual:
Oil Pump Installation (LT1 with Z52 Option, LT4)
Preliminary Procedure
If oil pump is removed to perform a different repair and is going to be REUSED, the alignment tool EN-51267 oil pump alignment tool MUST be installed on the engine block BEFORE the oil pump is removed and left in place until the installation of the original oil pump. If EN-51267 oil pump alignment tool IS NOT installed prior the oil pump being removed AND left in place while other repairs are performed, a NEW oil pump MUST be installed.
1
Oil Pump Assembly
Note: Prior to installing the oil pump, ensure that oil pump housing gasket is fully installed in the timing chain tensioner assembly and is not damaged. If the gasket is missing or damaged, replace the tensioner assembly.
2
Oil Pump Bolt
Caution: Refer to Fastener Caution.
Procedure
Tighten the oil pump bolts in the sequence shown.
Note: Upward pressure must be applied to the oil pump while tightening the fasteners. Contact between the oil pump housing and the oil pump alignment tool must be maintained while oil pump bolts are tightened. Prior to removing the oil pump alignment tool, ensure that there is no gap between the oil pump housing and the tool. If there is a gap, the oil pump bolts need to be loosened and the installation procedure repeated.
Tighten25 Y (18 lb ft)
Special Tools
EN-51267 Oil Pump Alignment Tool
For equivalent regional tools, refer to Special Tools.
1
Oil Pump Assembly
2
Oil Pump Bolt
Procedure
Special Tools
jschwab (01-05-2024)
1
Oil Pump Assembly
2
Oil Pump Bolt
Procedure
Special Tools
1
Oil Pump Assembly
2
Oil Pump Bolt
Procedure
Special Tools
I don't feel that the pump alignment process recommended by GM is the best option when reinstalling the pump. The tool ensures that the pump is clocked properly and reestablishes the vertical position but does nothing to ensure that the pump is positioned correctly in the horizontal direction. I prefer the feeler gauge technique.
Look just a few posts up about my feeler gauge issues. You can't get a single feeler gauge in there, I think that technique only applies to OLDER pumps or LS/WET SUMP pumps. It was impossible to get a single feeler gauge in there for my LT4 Dry Sump brand new oil pump. IMPOSSIBLE. Even the smallest feeler gauge I had the tolerances were so small wasn't happening. So NEW oil pumps have zero options but as the service manual states: Push up on the oil pump housing and tighten the bolts in the correct sequence.
I took a bunch of pics when building my motor. I'll see if I can find one that shows my shimming technique.
I was able to get three equally spaced pieces of shim stock between inner drive gear and the inner pump rotor on my wet sump LT1. I think I used .002 material but cannot say for sure. I will admit that the tolerances make the variable displacement pumps used on gen5 LT1/LT4 a bit more of a pain to align compared to gerotor pumps.
I would like to see some pics I'm curious how they differ. I don't know what the deal is with new LT dry sump oil pumps are maybe every one is different. All I know is I can't even get a sheet of paper in mine. In fact I couldn't find anything small enough to shim it. Really threw me off because its extremely small tolerance between the rotor and the housing. I will know when she cranks up!! Pray for me lol I hope to have the new motor in by next week. I will for sure have plenty of vids up when she's ready! Thanks for your input!
I couldn’t locate any pics with the shims installed, but I did locate a pic of the pump with the front cover removed. If you blow it up, you can see tiny gaps between the drive cog and inner rotor. I assume the dry sump pump is similar i.e. vane type, variable displacement pump? When I was building my motor, I was unaware of the pump design until I removed the cover. I was expecting to find a LS type, gerotor pump. I had to regroup and locate much thinner shim material in order to aligned the pump by as previously mentioned. For what it’s worth, I believe the specialty tool vendors may have sold GM a load of poles on this alignment tool. The plastic sleeves used with the oil pump mount bolts effectively locate the pump. It would be interesting to install the tool, apply DOWNWARD force on the pump, snug the bolts, and measure the gap between the locator tool and pump. My guess is it will not amount to much – obviously, I don’t advocate permanently installing the pump in this manner, I just think it would be an interesting data point. I still question this technique…the service manual does not say to apply any sideways force to the pump; isn’t there as much side-to-side play as up and down? Anyway, for what it’s worth, I have no oil pressure issues on my car. It stays right around 40psi at idle. Not sure what it is at WOT, but it has held together for 15K miles or so including lots of spirited driving and numerous track days. My guess is you will be just fine. Good Luck!
