C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
An fittings on valve cover location
Old 12-08-2018, 02:07 PM
g23crawler
g23crawler's Avatar
Default An fittings on valve cover location
Where is everyone mounting 10an bungs on the valve covers with keeping the coils in the stock location? And with out having oil issues, my first thought was at the rear on the driver side and at the front on the passenger side.
Old 12-08-2018, 06:12 PM
ZincGT
ZincGT's Avatar
I bought another passenger side valve cover with the oil cap and I run an oil fill adapter with -10 on both sides
https://www.mightymousesolutions.com...ll-an-adapters
Old 12-09-2018, 08:39 AM
jayyyw
jayyyw's Avatar
This is the easiest way.
Old 12-09-2018, 08:53 AM
CI GS
CI GS's Avatar
Received 1,110 Likes on 780 Posts
Agree with both posters above. The Mighty Mouse adaptor is one of the best inventions ever.
I have one of those with a single -12AN hose running from the passenger side oil filler location (see picture). My thinking is that if you need more pressure relief than that can provide, you probably need new rings...
Old 12-09-2018, 08:58 AM
jayyyw
jayyyw's Avatar
I run a -12an off my pass side valve cover, with the mighty mouse adapter and a -12an off the valley cover.
Old 12-09-2018, 04:28 PM
jashmore1234
jashmore1234's Avatar
Buy valve covers that already have them mounted and relo the coil packs:
Old 12-09-2018, 05:29 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
You can put bungs right around the center between the coils. Just make sure the baffle remains in place.
Old 12-09-2018, 07:05 PM
g23crawler
g23crawler's Avatar
I knew about the Mighty Mouse adapter and it works slick. But I already have bungs and a decent welder. So figured I would just do it myself and save some money. I was more worried about placement and excessive oil getting into the lines. But I think staying above the baffling I’ll be fine. Was hoping to see home pictures of other guys setups.
Old 12-09-2018, 08:00 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Had them on my stock covers before I switched to hollleys but I cant find a picture. Like I said, as long as the baffle is there, you wont have any issues.
Old 12-09-2018, 08:35 PM
EnginerdVT
EnginerdVT's Avatar
Is there any advantage/disadvantage to running them off the valley over running it from the valve cover?
Old 12-10-2018, 08:08 AM
jayyyw
jayyyw's Avatar
I run a hi rise intake, so I have a lot of space in the valley to run a fitting/line. I also use a baffled fitting for that location.
Old 12-10-2018, 10:55 AM
EnginerdVT
EnginerdVT's Avatar
I didn't realize they made baffled fittings. I'll check it out. Post a link if you can or PM me.
Old 12-10-2018, 11:48 AM
jayyyw
jayyyw's Avatar
They have 10an and 12an
https://www.jegs.com/i/JEGS/555/52230/10002/-1
jayyyw
jayyyw's Avatar
Jegs partnumber:555-52230
Old 12-10-2018, 04:21 PM
EnginerdVT
EnginerdVT's Avatar
All they have is the $50 Moroso one... figured. The Jegs one won't ship until New Years. Heard good things about Moroso one?
Old 12-10-2018, 04:55 PM
jayyyw
jayyyw's Avatar
Not sure. I run the Jegs 12an with no issues.
Old 12-11-2018, 06:51 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I have a set of holley covers with fittings welded on already. $100
To An fittings on valve cover location
Old 12-11-2018, 12:00 PM
freddyvette
freddyvette's Avatar
I run on the road course (~630 whp on a good day, NA). I experienced a lot of oil circulation when under heavy braking. I have a mighty mouse "wild" catch can with the re-circulation line.
I spoke with MMS about this and they suggested I add an AN fitting instead of the oil fill adapter. This is welded inside the baffled cavity so as to block direct fluid injection and drop out from the recirculating vapors.
It is perpendicular to the pushrod oil squirt, and the fitting elbow is facing backwards to prevent ingestion to the catch can when braking. It is also as high as possible to prevent gravity feed.
Old 12-11-2018, 01:51 PM
g23crawler
g23crawler's Avatar
I was going to put my passenger side as show but worried oil would gravity feed into the line. I happen to stumble across a used Mighty Mouse adapter today in the for sale section. So bought that and will use that on the passenger side for now. Going to weld up the driver side this week.
Old 12-11-2018, 02:58 PM
g23crawler
g23crawler's Avatar
I was planning on just running the race can, I know one side goes into the can but does the other side also connect to the can and everything vents out the top? Any benefits to using the pvc can besides not venting to the atmosphere? I just run filters on my turbos so I don't have a place to tap pre turbo.
Quick Reply: An fittings on valve cover location
