Calling Holley/Tanks Inc EFI gas tank owners
Please give any installation insights or tips on these monster, over engineered tank straps! Biggest problem I'm having is the hook portion that attaches to the tank support between frame rails. The strap hook end is longer than original and doubled over and spot welded farther up the strap (see photo). So its impossible to bend that portion, so the strap protrudes out from the tank support and then bends up and over the tank. It looks unsightly and also shortens the overall strap length which doesn't allow the use of both bolts to hold the bracket that allows strap to go over the sending unit on top of tank.
Barring any suggestions, I'm thinking of drilling out spot welds and cutting out a portion of the doubled over portion so the strap will bend up vertically earlier. Shouldn't have to do this so I feel like I'm missing something and just don't see it. Plus did a search and although there were mentions on difficulty bending straps nothing like this.
Thanks!
Thanks!
Thanks!
Thanks!
1) Bent the straps to match the old ones as much as possible
2) hook straps into the slots in the cross member
3) Push on the cross member to Slide the tank up into place
4) Put the two bolts into the straps in the back just loosely
5) Push the cross member into place and put the 2 bolts on each side enough to hold it in place. You will have to be pretty forceful here. This will start to bend the straps into their final shape. Keep an eye on where the strap goes over the wiring connections at the top and don't let it move around.
6) Tighten down the bolts in back then tighten the cross member bolts
7) Have a beer
Thanks Scott for the very detailed process ... very helpful! One question ... Prior to starting the process, did you attach the passenger side strap to the provided guide that goes over the sending unit with both bolts?
Double check your fuel line tightness. I even used some aviation gasket sealer because it was a pain finding a leak after it is up in there.
gearheadz (12-10-2018)
After trying to anticipate where the bolts needed to be for several fits, I left them loose on the final fit so it could adjust as the straps tightened. That helped and the straps certainly hold it in place.
The only problem with the original straps are that they do not have the slots for the spacer over the sending unit. I personally thought it was going to be more of a hassle to cut those into the strap than form the straps correctly. Using the new ones is super easy.
Here is a picture of mine. Used the Tanks straps and seemed to work fine. Hope it helps.
The front side of the tank as well.
73racevette (12-10-2018)
73racevette ... Nice! I notice the hooks that go into the slot on the tank cross member are bent differently than how they come from tank vendor. I assume you bent those to fit? See my attached photo. I can do the same as yours but I'll have to heat the strap with a torch and re-bend to conform to crossmember slot.
No heat needed with mine. Just a bit of elbow grease to stretch them over the tank. Mine looked just like yours out of the box.
