Borla x-pipe/Corsa Extreme cat-back
Anyone ever try this combo on their Z06? I currently have the catless borla x pipe and would like the corsa extreme exhaust. It appears that it should bolt right to the back end of the borla x pipe but I wanted confirmation.
I had this set up for 2 weeks, it sounded good but it was kind of weird because the sound seemed to be only coming out the back/the sound was coming from further away if that makes sense, there was no sound in the middle and when I swapped to the corsa xpipe the sound started coming from the middle (better) and I think it was because of how good the borla fitment was and that there was no leak so the sound was coming out the rear only but the corsa xpipe is not the best quality in my opinion, installed a brand new one and the fitment was meh and I had exhaust leak but its okay because the sound started coming out the middle a little so I could her better, but overall the tune remained the same in my opinion, dont waste your money on corsa xpipe stick with the borla's
Did you like the sound better with borla/ Corsa set up? Your description of the sound with this set up seems like a good fit but as far as the exhaust note which did you prefer. I'm on the fence going with borla xpipe and borla npp, I only drive in sport and track so npp functionality is not something I care too much for. I have also read quite a few people who went with the borla mufflers and we're disappointed it wasn't loud enough.
This is what originally lead me to purchasing the borla over Corsa xpipe. I read alot of people having issues with leaks. The noise diff is prolly because the xpipe that Corsa makes rejoins towards the end of the mid pipe. The only down side I foresee going Corsa is having to cut the mufflers off by the AFM. Did you install them yourself and cut the stock mufflers off? Or did you take it to a shop for install?
My car is a Z06 so I didnt have to deal with AFM valves and I went with full corsa which included the mufflers too. As for cutting up your mufflers I dont think you need to because as far as i know both the borla and the corsa fit the oem exhaust. I was under the impression you wanted to go full corsa (mufflers included) but if your only doing xpipe stick with borla because their quality is definitely better than corsa. And as for the sound before the corsas I had the magnaflow with the borla xpipe and the sound was great in the cabin but just a little drone so it was really weird when I swapped corsa mufflers that the sound in the cabin became really quiet which I think is because of how well the borla xpipe fit the mufflers but now that I swapped to corsa and there is a bit of exhaust leak the sound is back in the cabin so im okay with a little bit of leak. I had a shop install it and it was straight forward
Amirns (12-13-2018)
