DeLam'd Windshield replaced - got a leak now
Old 12-10-2018, 12:38 PM
RiCorvette
RiCorvette's Avatar
Default DeLam'd Windshield replaced - got a leak now
My 17 GS suffered the seemingly common internal stress crack (Pass A Pillar to roof) and delaminated along the top edge. The Windshield was replaced under warranty and now I have a leak, but not from the windshield - the weather strip on the passenger side A Pillar / Window is the culprit. as evidenced by visually confirming the leak while washing.
Would replacing the weather strip be covered under warranty, or is the Glass Repairman Subcontractor responsible, or am I SOL and responsible to replace the weather strip myself?
I Googlesearched and I perused GMPartsdirect.com, and etc. but couldn't come up with a P/N for just the Weather Strip that seals the A Pillar / Window interface - can a Forum Member please provide the P/N? - TIA!
Old 12-10-2018, 12:47 PM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
It depends on who arranged for the windshield to be replaced.
If the dealer did, then make the leak their problem.
The following 2 users liked this post by PatternDayTrader:
4thC4at60 (12-10-2018), Avanti (12-11-2018)
Old 12-10-2018, 02:59 PM
Virtual Geezer
Support Corvetteforum!
Virtual Geezer's Avatar
You're still within the 36/36000 original warranty. Mama Chevy covered the windshield, she should cover the leak problem with the weatherstrip. If the subcontracted windshield installers caused the problem, it's up the GM/dealership to recover the cost -- not you, you did not cause the problem.
Old 12-10-2018, 05:46 PM
speedlink
speedlink's Avatar
I guess I don't understand the question. The installer needs to make it right. If it wasn't leaking before replacement, then it was caused by the replacement labor.
Old 12-10-2018, 05:57 PM
PatternDayTrader
Yeah but they aren't going to do anything about it. Instead they will just say "it was like that that before we did our work" or something similar.
Old 12-10-2018, 06:15 PM
RiCorvette
RiCorvette's Avatar
CTOF - 'Check The Obvious First' is a rule I try to live by. That being the chase here, the problem didn't exist before the Windshield Replacement and should be covered by Warranty/Dealer//Subcontractor. HOWEVER, since it is an easily replaced Weather Strip, I may forego the misery of dealing with it and just replace it myself - depending on the cost.
In any case, a P/N for the A Pillar/Window Weather Strip is wanted; 2017 GS Coupe. - can anyone provide it?
Googlesearching didn't help.
Old 12-10-2018, 06:49 PM
PatternDayTrader
Just call your local dealer parts department. Unless there is a GM parts guy here, you wont find the info you are looking for. Kevin Jones is basically your only chance, but I think he is living well in retirement.
Old 12-10-2018, 08:52 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Weatherstrip seems to be a single piece for windshield frame:
Old 12-10-2018, 09:08 PM
RiCorvette
RiCorvette's Avatar
That seems to be it - thanks!
Part No.: 84367842
WEATHERSTRIP ASM-W/S FRM
To DeLam'd Windshield replaced - got a leak now
Quick Reply: DeLam'd Windshield replaced - got a leak now
