C3 Parts for Sale/Wanted C3 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
WTB: Oil pressure line fitting to block.
Old 12-10-2018, 01:45 PM
tfringo
tfringo's Avatar
Default Oil pressure line fitting to block.
Looking for the threaded brass oil line fitting for a big block. This is the larger one that screws in above the oil filter. The center is tapped for the oil line to screw into it. If you think you have one, send a PM. Thanks.
Old 12-11-2018, 12:33 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
should be standard 1/4" NPT into block, ... with 1/8" compression fitting for oil line.
choose a plumbing supplier.
tfringo (12-13-2018)
Old 12-11-2018, 04:59 PM
tfringo
tfringo's Avatar
ttt
Old 12-11-2018, 05:00 PM
tfringo
tfringo's Avatar
I wanted to find an original just in case there was something unique to it. But, I might end up going that way. Thanks, Terry
Old 12-12-2018, 07:48 AM
toylman
toylman's Avatar
Is this the one?
https://www.ebay.com/itm/Corvette-oi...00%7C7000%7C10
tfringo (12-12-2018)
Old 12-12-2018, 10:07 AM
Street Rat
Support Corvetteforum!
Street Rat's Avatar
Or this one?
https://www.corvettecentral.com/c3-6...e-brass-303108
Old 12-12-2018, 10:28 AM
tfringo
tfringo's Avatar
Default Fitting
I
Thanks, but no. I was hoping to avoid buying a reproduction. The one I am looking for looks like a threaded plug with a hole drilled/tapped in the middle to accept the oil pressure line fitting. They do sell them in reproduction but I wasn't certain if they have any special markings on them. It is the one in the left lower of the photo that the 45 degree fitting is screwed into. It looks like a common fitting. Thanks
Old 12-13-2018, 08:28 AM
tfringo
tfringo's Avatar
Default Fitting
Looks like this..
Old 12-13-2018, 05:50 PM
grantstigers
grantstigers's Avatar
Originally Posted by tfringo
Looks like this..
Terry
It has no markings
Just the other angled brass plug that goes into it has the W weathered stampings
How've you been haven't heard from you in a while
Grant
tfringo (01-27-2019)
To Oil pressure line fitting to block.
Quick Reply: WTB: Oil pressure line fitting to block.
