FS: Misc Corvette Parts, mostly new.
Misc Corvette Parts, mostly new. Prices lowered!!!
Prices are plus actual shipping cost. The prices are all well below new price I paid. Most parts came from Ecklers or Willcox. Can have photos upon request.
C3 Corvette Convertible Deck Lid $250.00
New Gas tank straps, 1974 to 1977 $15.00
New Electric antenna $55.00
New Antenna ground plate/support $15.00
New Lower Radiator hose, late 76 to 82 $10.00
New Upper Radiator hose, late 79 to 82 $17.00
New Gas Pedal, full size chev, 1958 to 1964$10.00
New Upper and Lower A-arm bushings these are the good ones from Willcox $25.00
65 to 82 Corvette aluminum brake pistons with new seal kit $75.00
New Differential front poly bushing kit, new $10.00
New Three 65 to 82 axle french lock $5.00
New Stock 7/16" rear sway bar poly bushing kit. $20.00
Used Differential stabilizing kit with poly front bushing $20.00 these are the aluminum disks that go on the crossmember sombrero mounts to reduce play.
New Brake console bezel $15.00
Used MSD Adjustable Timing Module for HEI $85.00
New Headlight Actuator Covers $20.00
New Heavy Duty Differential Side Yoke U-joint Caps and bolts. $40.00
Mike
Mike
Wondering if you have pics of the roll bar kit thanks
Thanks for pic I'll pass to Beautimus Phil
Dementer sole survivor
Received 6,291 Likes
2016 C3 of Year Finalist
do you have pics and a part number for the electric antennae
PM Sent!
