Crossfire guys, check my parts before i go assembling this thing.
Hey guys. Just wanted to make sure im not doing anything that red flags to my 84 corvette.
promaxx 180cc aluminum heads 64cc chambers
Comp cams 12-242-2 + lifters and pushrod kit
felpro gaskets and seals
renegade intake manifold
tbi "police interceptor" injectors (86lbs. ?) Fuel capability at max duty cycle
Stock transmission (auto 700r4) (not sure i will be able to run this engine at full go through the tranny till it is rebuilt. Ive heard that the 700r4 limits at about 350 ft. Lbs. Torque. Correct me if im wrong)
Dynamic EFI EBL Flash II ECM
New HEI distributor
New plugs (anyone got a good sparkplug brand or just stick with ACDelco?)
90' C4 fuel pump.
make sure im not on my way to trouble and we'll be good to go guys!
New HEI distributor
90' C4 fuel pump.
What about your exhaust? You have to be able to get that new air flow out as well.
You're repinning the ecm connector or do you have a ham board too?
Check the intake over very carefully and make sure all the gaskets line up.
Your static compression is going to end up around 10.25:1 which brings your dynamic around 8.5:1. There is more than compression in play but I'd be willing to bet you have to run 91+ and may have some pinging issues still. Personally I'd run a 70cc chamber and play it safe or go to a slightly larger cam.
The stock exhaust is fine but you're going to leave a ton of power on the table.
Depending on fueling you may need a variable fuel pressure regulator...
I want to build mine but I also only want to do it once... because of that I'll probably just build up a roller block. It's a lot less headache in the long run and you can build that well beyond what a crossfire system can ever handle.
When you go to rebuild it, post a thread and you can upgrade it with stock parts (Newer "E" stuff will retro) to more than handle your combination. Shouldn't cost a fortune either.
No problem. Don't even worry about it. Enjoy your build..
hey man. so im wondering about this. does that mean the engine will run rougher? I want this to be streetable so I don't want to kill off parts that make the engine run well. also, if I put the egr back onto the engine but it doesnt have the crossover ports will the engine still run well or will that severely affect performance?
Thanks for the info! I have a few questions about what you said. firstly this is a streetable engine. or that's the goal at least. Will it run fine on premium gasoline 91? or will I constantly have to use octane additive to run the car well? secondly, I got a quote from my local build shop to do a cat back 3" dual exhaust with an X pipe for about 400$. is 3" too much or to little? do I need bigger headers and piping from the Heads back to the cat to accommodate a 3"+ true dual system? Thanks!
There are guys on here that know way more than I do, and I'm sure you have local builders you can talk to who know a thing or two as well.
Yeah man. I've heard that. would your order the intake from eddie or from summit, jegs maybe? I wanna build the engine up so that as soon as I get the intake in I can dry fit it to make sure it works. If it doesn't I wanna be able to get a new one from customer service as quickly as possible. which one of those websites have the best customer service in that regard?
